Shifter Spring
  • 2305 Views
Offline Amilla
  • 1076
Shifter Spring
« on: April 26, 2010, 05:11:03 PM »
Have a 93 Sidekick transmission.
When I pulled the shifter out of the trans, I found that the tapered spring that is on it was broken.
I don't to buy a new one, just figured I would pull the old shifter apart and try and replace the spring.
Only problem is the spring was so far destroyed, the only measurement I can get from it is the gauge.
To make a long story short, can anyone tell me the size of this spring?  Length and diameter(Large end/small end).
Thanks a lot.
Amilla
Re: Shifter Spring
« Reply #1 on: April 28, 2010, 06:23:38 AM »
I cant give you the dimensions, but, I had the same issue a while back and Hawk shipped me one out, same day, and cheap.. Give them a try... 1-888-SAMURAI
Offline Amilla
  • 1076
Re: Shifter Spring
« Reply #2 on: April 28, 2010, 12:53:01 PM »
Thats cool.
I talked to Sean at Lowrange and he was saying that a used shifter was 75 bucks.
But I found the same style spring through Mcmaster Carr.  Figure ill just order up a few springs with similar size, pull the old shifter apart and see what I can do.
That spring just keeps tension on the retaining cup right?
Pretty sure I could use any spring, as long as its not to loose.
Thanks a lot
Amilla
Re: Shifter Spring
« Reply #3 on: April 29, 2010, 05:08:20 AM »
Yea, It keeps the locking cap in place... Be sure to get one that fits tight... I had an old one that did not hold the shifter tight in place and it's annoying....
Offline mypocketsrfull
  • 89
Re: Shifter Spring
« Reply #4 on: April 29, 2010, 10:00:00 AM »
hey amilla, you CAN order from mcmaster, i am not sure how much they will charge you, but I (like zukipilot) went through hawk and they charged i believe $2.00 plus shipping. not sure what kind of deal you are getting from mcmaster,  but at least you know the one from hawk will fit
Offline Amilla
  • 1076
Re: Shifter Spring
« Reply #5 on: April 30, 2010, 11:27:53 PM »
You can get the spring through Hawk?
Amilla
