wedge
  • 2497 Views
Offline dupont#24
  • 48
  • Deer hunter
wedge
« on: April 30, 2010, 07:15:23 PM »
I am in the process of installing power steering on sammy I have the TT kit with petroworks wedge  Ihave bolted the wedge  to the frame and I can not get the pump to bolt to the wedge I think it is hitting the back of the grill did anybody have to bend there grill to make this thing line up.The back of the steering box is hitting I think.I have just heard that this thing is a simple bolt on .Boy I am having a time with it .I have a shrockworks bumper it may be hitting it to. Pics would be really nice to (help)
Offline dupont#24
  • 48
  • Deer hunter
Re: wedge
« Reply #1 on: April 30, 2010, 09:30:23 PM »
anyone anyone
Re: wedge
« Reply #2 on: May 01, 2010, 03:46:18 PM »
Dude, you gave it 12 hours.  On the more unique ones you usually have to wait a day or two for the right person to log in.
When setting the power steering unit in place can you not see if the unit is rubbing up against something?  Or is it to dark where you are doing the installation to be able to check for clearances?
Have you tried just calling Petroworks?
Offline dupont#24
  • 48
  • Deer hunter
Re: wedge
« Reply #3 on: May 01, 2010, 08:23:03 PM »
Finally got it in this morning I was getting a little impatient last night I had started on it pretty late and it got dark on me. I am the person that when I start something I think I have to get it done then.It was the shrockworks bumper I had to get the torch out this morning  and notch out a little.Worked perfect after that everything bolted right up works great.Let me ask you something Do I need to hook up the factory steering stabilizer back to the pitman arm.I have a aftermarket stabilizer on the crossover steering from TT
Offline my996duc1
  • 222
Re: wedge
« Reply #4 on: May 01, 2010, 09:48:12 PM »
I had the problem with my Shrockworks bumper... but the other way around.
I had the power steering then went to put on my new bumper and had to knotch it.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Re: wedge
« Reply #5 on: May 03, 2010, 02:20:18 AM »
One stabilizer should be more then enough.  When the Sammy in our club went to the Sidekick power steering he didn't even bother running a stabilizer.
Offline yzf438
  • 94
Re: wedge
« Reply #6 on: May 04, 2010, 09:09:26 PM »
I took a look at that wedge online and built my own.  was easy.  used mercades steering arms  did some work on my draglink (shortened it) and put high steer in like that.
after I did that I took a look at the steering.  I have long shackles in front with the spring over.  wow what a bunch of play. when I turned the wheel. everything rocked from the lift.  if u  find that in yours with the power steering put in a panhard bar.
what a differance that made on the whole set up.  thing turns on a dime now and not a bit of bump steer
