holes in top of distributor cap
  • 7 Replies
  • 2767 Views
Offline airdale navy
  • 82
« on: May 03, 2010, 04:20:14 PM »
Rotor rubbing holes in top of distributor cap.It  looks like there was a gasket at bottom of distributor that cracked ,dried&missing.Can use a O-ring ?Or is something special?
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
  • 82
Re: holes in top of distributor cap
« Reply #1 on: May 03, 2010, 04:21:01 PM »
This is 91 sidekick.
Offline fordem
« Reply #2 on: May 04, 2010, 10:24:37 AM »
There should be a plastic cover and an O ring or cap gasket there - the O ring is not your standard circular cross section O ring, but a rectangular or flat one - you could try a standard round O ring but there is a possibility that the shape may cause it to slip out as the cap is tightened down.
  • 82
« Reply #3 on: May 04, 2010, 06:22:21 PM »
The hole are burn Thur the top of the cap in a long thin areas .In four spots.I put a O-ring under it Have a .040 gap between cap and distributor place ,does that sound about right?
Offline rascott
  • 669
  • 15
« Reply #4 on: May 04, 2010, 11:32:38 PM »
there is a gasket between the cap and dist. body. tip of the rotor was hitting the cap? must have been grinding out the center too, huh.
gasket material could work also. bet the o-ring is working for you?
« Reply #5 on: May 05, 2010, 09:58:03 AM »
Sounds like you need to get the right distributor cap and rotor, might be
the wrong parts were in the last box
  • 82
« Reply #6 on: May 05, 2010, 05:50:47 PM »
Well it was not rubbing . Found timing WAY advanced about 30 degrees.I cant believe it was running.
« Last Edit: May 08, 2010, 05:16:42 PM by airdale navy »
« Reply #7 on: May 08, 2010, 04:05:49 AM »
WOW! How did it run like that, I mean performance wise?
