Motor Hesitation
  • 4255 Views
Offline TX-Trak
Motor Hesitation
« on: May 04, 2010, 07:54:39 AM »
I have noticed that my newly acquired 95 16v tracker has some hesitation when when trying to accelerate.  This only seems to occur when i first start it and begin to drive.  after the engine has run for a while and is nice and hot, it does not occur.  Any thoughts?
95 tracker manual 4x4
02 Dakota Quad Cab
Re: Motor Hesitation
« Reply #1 on: May 04, 2010, 07:19:32 PM »
coolant or air temp sensors, my vote is for the coolant temp sensor
Offline Nick1236
  • 31
« Reply #2 on: May 28, 2011, 08:08:41 AM »
Bringing back the dead...
I get a similar problem on my 95 sidekick 16v. I get hesitation in the 2.5-3k rpm range or when the gas petal is about halfway. If i hammer on the gas and let it rev up higher (about 4-5k before shifting) it goes away some. I'll clean everything out later today with some throttle body cleaner. Any other suggestions?
Offline Foot
  • 76
  • Nothin Like It
« Reply #3 on: May 29, 2011, 08:16:41 PM »
If it occurs at the same point of throttle it'spossibly a throttle position sensor. Also check for any vacuum leaks.
HIT IT !!
Offline mbruce
  • 139
« Reply #4 on: May 30, 2011, 02:28:58 PM »
My 1.6L/8v does the same thing....
I changed the coolant temp sensor and no fix...
I could not locate the air temp sensor.... maybe it's MIA and that's my problem. ha
I'll check for vacuum leaks -- Just curious -- if it is a vacuum leak why would the issue only happen at startup and correct itself and run like a champ when it gets warmed up?
Ignorant questions lead to a wealth of knowledge
« Reply #5 on: May 30, 2011, 05:14:18 PM »
Check your timing.  I run mine about 6 degrees of advance over the stock location.  Before that it had a hesitation around that RPM range.
Offline Foot
  • 76
  • Nothin Like It
« Reply #6 on: June 02, 2011, 07:05:01 AM »
metals have a tendancy to expand when heated. the reason i said that was because i had a metal vacuum tube on the side of my plenum that was cracked and that joker took forever to find.
HIT IT !!
Offline Nick1236
  • 31
« Reply #7 on: June 02, 2011, 01:41:33 PM »
OK. I had a stalling issue when the car would come to a stop but only when at full operating temp, 180-195 deg F. I replaced plugs, wires, valve cover gasket (was bad), fuel filter, cleaned the MAF, cleaned the TB, cleaned the EGR (EGR main, havent done the tubes yet. Checked with a vacuum tool and it functions), cleaned the PCV valve and adjuested the TPS sensor to within specs. The stalling issue went away.
However, I'm still having hesitation in all ranges. Anyone have any other ideas?
« Last Edit: June 03, 2011, 07:29:02 AM by Nick1236 »
