Auto trans leak risk
  • 2163 Views
Offline keith
  • 1176
« on: May 07, 2010, 08:42:36 PM »
My 3 speed automatic seems to be leaking about 5 ounces of fluid each 250 miles or so.  I keep adding it as needed to keep it in the operating range.  Other than the mess on my garage floor is there a risk to the transmission in doing this?  I've put 4000 miles on the vehicle since last August when I bought it.  It shifts well but it does take a second or two to engage reverse.  I have changed the pan gasket but that didn't solve the issue.
« Last Edit: May 07, 2010, 08:47:06 PM by keith »
Re: Auto trans leak risk
« Reply #1 on: May 08, 2010, 03:59:09 AM »
As long as you keep filling it the risk to the trans is minimal, ( but IMO still unacceptable) but your garage floor and the general enviorment is still at risk! you should really try and find the leak and fix it. A lot of the autos leak at the shift mechanism on the passenger side of the trans. Clean the area thouroughly and keep an eye on it.
Offline 89tracker43000
  • 47
  • my tracker
« Reply #2 on: May 12, 2010, 11:17:17 AM »
it also could be one of the hoses that goes to the bottom of the radiator check them out to.
« Reply #3 on: May 14, 2010, 06:28:59 PM »
My 3 speed auto has been leaking it's whole life, I think it's just the way they are.
I have 290,000 miles on mine, and it's never been out of the truck, and It also takes
it's time going into reverse, always has
Offline keith
  • 1176
« Reply #4 on: May 16, 2010, 05:41:07 PM »
Wild, any idea what rate yours leaks at?  My 90 also leaked but not as much as this one does.
« Last Edit: May 16, 2010, 06:39:20 PM by keith »
« Reply #5 on: May 16, 2010, 07:06:43 PM »
About a quart every 1000 miles
