gas gauge does not read?
  • 1709 Views
« on: May 11, 2010, 07:07:15 AM »
anyone have this problem? gas guage and water temp dont show a reading,they just sit there at the bottom looking lonley.
can it be fixed and how easy/cost?
Offline 89tracker43000
  • 47
  • my tracker
Re: gas gauge does not read?
« Reply #1 on: May 12, 2010, 11:11:44 AM »
first i would check the fuses then the connections behind the gauge cluster to see if maby one of them came unhooked or it could be a ground. there is a few things that can happen to make this happen like loss of power or ground bad connection or the gauges them selves are bad its not hard to fix once you figure out what is wrong. hope this helps some
