engine from a 5spd into an automatic
  • 2273 Views
« on: May 11, 2010, 11:53:25 AM »
hey i currently have a 96 sidekick 1.6 16v 3spd auto with and engine that is dying. i can get a rebuilt engine tranny transfercase from a 92 kick 5spd manual that has low kms and more importantly runs great.
my question is ..is it possible to rip the tranny off the 92 and bolt up that engine to my existing auto tranny, if so what else will i need, or need to take off such as the clutch or flywheel for example?
ive never pulled an engine out so im in need of some good advice explaining my situation
has anybody done this swap before?
Re: engine from a 5spd into an automatic
« Reply #1 on: May 12, 2010, 04:06:48 PM »
There are going to be a few differences between a 92 16V and a 96 16V.  The 92 is OBD1 and the 96 is OBD2.  So you will need to swap your intake manifold over to the 92 head, so all the 96 wiring will plug in.  You will have to swap the 96 distributor over to the 92, since the 96 distributor has the coil built into it, where the 92 doesn't.  You will need to swap the 96 oil pump, oil pan and lower timing belt pulley over to the 92 engine, because the 96 has a crank position sensor located on the front of the oil pan, so the oilpan has a hole in the front where the sensor mounts and it reads off the lower timing belt pulley which has "teeth" on it, and the oil pump has a hole in it so the sensor can "see" the teeth on the lower timing belt pulley.  You will likely need to swap exhaust manifolds too, since they will be different and the 96 exhaust piping won't directly fit the 92 manifold.
So in short....you will basically only be able to use the block and head of the 92....everything else will need to be swapped from the 96 to the 92.
And as far as swapping a flywheel/clutch onto the back of an engine that originally had an auto behind it.....you just have to remove all the auto tranny stuff (flexplate, torque convertor, etc.) and swap the manual stuff onto it.
