Any other High-output alternator upgrades?
  • 16 Replies
  • 8189 Views
Offline wiretap_MD
  • 73
  • Where the Road Ends...Life Begins!
« on: July 07, 2004, 08:16:24 AM »
..aside from the Petroworks 105A which sells for $2xx. Thanks!
'01 Sidekick: OME-Calmini Hybrid Suspension, 1.5-inch spacers, Bilstein 5125 re shocks, 2-inch bodylift, 30x9.5 BFG, Safari Snorkel, ARB bumper, Custom rear bumpe
Offline 1bigtracker
  • 3409
Re: Any other High-output alternator upgrades?
« Reply #1 on: July 07, 2004, 03:03:20 PM »
duel batts?
stu
« Reply #2 on: July 07, 2004, 04:37:40 PM »
duel batts?
stu
And where would you put them in a Tracker?
The back seat?
I was thinking yuou can turn your battery sideways in the tray and fit 2?
Maybe not.
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #3 on: July 07, 2004, 05:20:18 PM »
Ok, so I can make two fit... #1 Why am I doing this? #2 How do I use them once they're in? I like upgrades, so I'm looking into a winch and fog lights, so there are other alts. that you can put in a Kick? Pics would be fun if anyone got them.
steveo
Offline idaholwb
  • 772
« Reply #4 on: July 07, 2004, 05:28:06 PM »
 If you go with GM style alt conversion, it would power a dual batt system, winch, whatever you need.
Quit being so cheap people. Just be glad you don't own a Jeep or a Toy, or a Land Rover, or.....? If you owned any of the above you would be into the same kinds of mods at least twice that much! And you guys wonder why no big companies want to start dealing with our world.
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #5 on: July 07, 2004, 06:20:55 PM »
Offline supazuk
  • git 'er done!
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
Offline wiretap_MD
  • 73
« Reply #7 on: July 08, 2004, 02:42:21 AM »
Most of the links and kits are for the Samurai.  What I'm looking for is a high-amp alternator kit for the 4-door Sidekick with the 1.6L 16V engine.
Crabzuki
« Reply #8 on: July 08, 2004, 04:24:03 AM »
Why so harsh on the guy's here? If anyones cheap maybe it's the fact you can build a good ride for 10,500 and under and that's cheaper than buying a new rig. So if you want more power (amps) do it right the 1st time so that you don't have to keep adding to it, nickle and dime'n you to a point where it should have been done right  the 1st time around. NO MICKEY MOUSE work is exceptable unless you wish to be left stranded in the back woods without help.  ;D
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: July 08, 2004, 04:43:36 AM »
The samurai bracket will bolt up on a 16v. the prob your going to have is finding a gm alt with a mini serp.
Offline 1bigtracker
  • 3409
« Reply #10 on: July 08, 2004, 05:05:15 AM »
The back seat?
Maybe not.
well i was thinking about mounting a second Optima on its side under the pass seat.  in a box of corse.
stu
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #11 on: July 08, 2004, 05:29:41 AM »
Ill probly do a rocky road alt bracket and a GM alternator and a Optima battery
01 GRAND VITARA
Offline Mike71
  • 1449
« Reply #12 on: July 08, 2004, 06:08:08 AM »
this is what i was gunna do kinda what im still gunna do..since i need 10x the power i have now i was going to do the GM alt braket (already purchased) then from the excesiveamperage i am going to run his delco 2" gm alt 200amp came to like 240$ with the pully so it would bolt right to the zuke belts and stuff
then (since i dont have a back seat just subs) i was going to run 1 yellow top under the hood and 2 red tops behind the seats that would power a small city =) lol
but that may be a little much for u..however i suggest u do not skimp now on the alt since eventually u will want to run some type of winch with off road lights..that 100amp alt will do alright..but the 200amp alt would take all the punishment without and signs of wavor
on my 91 u could pount a 2nd batt and the hood opsite the stock location (takes some imagination) but my SVR (kinda like an optima only has more output and half the price lol) will fit over the wheel well on its side
u also need to remember when running duel batts u will need some type of isolator (200amps to match the 200amp alt) u will also need wiring that can support the 110amps at idle and 200+amps at 2400rpm
Offline supazuk
  • git 'er done!
« Reply #13 on: July 08, 2004, 03:38:17 PM »
i bought the trail tough one ... its cheaper then Rocky road ( by about half) and is great quality ... they wire harness is avalible at any junk yard for $FREE.99 or auto parts store for a few bucks  easy to figure out .. if you still need help roadless gear has an great write up on the wiring so does www.off-road.com in the zuk section .. as for the pulley some early cavalers had them
Offline idaholwb
  • 772
« Reply #14 on: July 08, 2004, 04:04:59 PM »
Sorry about that. But I have heard more people on here and elsewhere, complain about how much things cost for these cheap little trucks. My main gripe IS how cheap they are to build, and most people still complain about spending more than $20 on them!
Sorry, had to vent.
97 Sport
265/70-16s
2" lift
2.0 swap
