1988 suzuki samurai with 1.3 motor
  • 2643 Views
Offline audiman
« on: May 15, 2010, 03:46:28 PM »
I found a 1998 Geo tracker with the 1.6 16 valve motor. Will that fit in my 1988 samurai. The Geo tracker is obd 2. I want it to pass smog in the sate of California.
1988 samurai
Offline my996duc1
  • 222
Re: 1988 suzuki samurai with 1.3 motor
« Reply #1 on: May 15, 2010, 09:00:33 PM »
Yes, it will fit.
Not sure on passing smog in CA as an OBDII.
The smog machines read off of the computer as to it being OBDI or OBDII. I know you can take an OBDII engine and use an OBDI computer and it will smog check as an OBDI.
Not sure what all is involved, just know it can and has been done.
You might try calling a couple of the companies the make the conversion wiring harnesses such as Trail Tough or Petroworks...
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
