Put 5.125 finals under my 3spd tracker...
  • 2910 Views
Offline yellow2000S/R
  • 152
« on: May 15, 2010, 09:58:40 PM »
WOW, I knew there would be a difference but not this much!
I'm on 30x9.5 BFG A/T right now and before with the 4.30:1 stock gears the speedo read 3-4 mph less then what I was traveling. NOW, with the 5.125 gears, it reads 9mph fast at 60mph.
It gets up and goes faster tho and with it reading wrong the TC locks up still at 47mph per the speedo reading but only traveling 40ish mph so driving around town the rpm will be lower but highway looks like 60mph will be about the max running the speedo around 70mph and 4k rpm.
Is there anyway to run something to make the speedo/odometer reads correct so it doesn't run my mileage way up?
Time for some 32s or 33s to offest this some!
« Last Edit: May 15, 2010, 10:00:39 PM by yellow2000S/R »
Re: Put 5.125 finals under my 3spd tracker...
« Reply #1 on: May 15, 2010, 10:39:14 PM »
Ya, put in the manual trans speedo drive gear, it will then read closer to correct
Offline my996duc1
  • 222
« Reply #2 on: May 16, 2010, 01:36:59 AM »
sent you message about your 4.30 gears....
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #3 on: May 17, 2010, 04:56:44 AM »
You have to change BOTH speedo drive gears, the inner one is on a shaft in the t case which requires removing the back of the case.
« Reply #4 on: May 17, 2010, 08:37:43 AM »
Ohh, I didn't know about that, both gears looked the same to me  ???
« Reply #5 on: May 17, 2010, 12:33:53 PM »
I thought the answer was to install the GPS and ignore the speedometer.  :D
  • 152
« Reply #6 on: May 17, 2010, 02:17:33 PM »
Eh, traveling 60mph the speedo reads just shy of 70 mph... but around 4k rpm IDK how much highway driving I'm going to do with it till I get some 32 or 33" tires to offset it some.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #7 on: May 17, 2010, 03:03:57 PM »
I just swapped a t-case from a 3 spd auto (4.6's) into a Kick that ran 4.8's from the Factory and the speedo didn't work as the gear inside the t-case is too small a diameter to engage with the drive in the end of the speedo cable. Swapped the drive and it now works fine. The 5.12 geared Kicks have the same size speedo cable drive as the 4.8 geared ones so that hasn't been a problem swapping between them.
« Reply #8 on: May 17, 2010, 03:13:04 PM »
I'm with that, and really, just drive the tach. You do get used to it though, when mine reads 57 I know I'm going 65, 62 is 70, and after that I'm too busy trying to watch the road!
