Catalytic converter advice needed!
  • 9 Replies
  • 2972 Views
Offline airdale navy
  • 82
« on: May 16, 2010, 05:28:21 AM »
I need to replace my CAT on my 91 sidekick 8V.I was looking at a magnaflow but Autozone's web site give them a really bad review.I'm also looking at a Walker super converter .Has any body had problems with either one? ???
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Re: Catalytic converter advice needed!
« Reply #1 on: May 16, 2010, 08:08:29 AM »
Both brands have a good reputation, I had a walker muffler, but the cat I got was
just the cheapest I could find, most don't last more than a few years according to
the smog tech I talked to.
OEM Cats are the best, designed to last like 50K Miles to meet the Federal smog
warranty required on all new vehicles
Offline Bill S
  • 30
« Reply #2 on: May 16, 2010, 07:24:51 PM »
This is what I put on my '92 and it works just fine. If you poke around on ebay you can find cheaper ones.
http://cgi.ebay.com/ebaymotors/Universal-Hi-Flow-Catalytic-Converter-1-3-4-2-1-2-_W0QQcmdZViewItemQQhashZitem2ea7da96c7QQitemZ200384616135QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
You can also get 5' of SS pipe for the same price.
Bobthebiker
« Reply #3 on: May 16, 2010, 08:30:12 PM »
only two problems are, that stainless pipe in place of converter=SMOG FAIL,  and also gets you in trouble since I believe the cat is a federally mandated component.
I'm simply doing a high flow, because as much as I dislike the converter, it needs to be there by law.
Offline igaug
  • 40
« Reply #4 on: May 17, 2010, 12:20:08 AM »
everything is straight piped in kansas! no inspections...
  • 82
« Reply #5 on: May 17, 2010, 03:08:17 AM »
Straight pipe?Don't you need some back pressure in daily driver?
Offline igaug
  • 40
« Reply #6 on: May 17, 2010, 08:08:33 AM »
some leave only the cat, no muffler or visa versa... i wouldn't straight pipe anything i drive but people do bcuz they can get away with it here.
Offline fuzzy1
  • 350
« Reply #7 on: May 17, 2010, 11:06:11 AM »
Questions for you on that converter Bill S:
1: does your egr still function correctly, ie no code 51 or p0400?
2: how did you address the rear o2 sensor bank? Or does the 92 not use one?
Non Illegitimi Conterat
« Reply #8 on: May 17, 2010, 12:20:58 PM »
The 92 doesn't have one.  :)
That being said, I recommend running a cat on anything other then a trail rig.  It really is better for the environment, even if it is a pain in the ass.
  • 82
« Reply #9 on: May 17, 2010, 02:11:38 PM »
I'm not getting any engine codes.EGR Is working.Just bad mileage .Seem to rev slow under 2500 rpm's.It was burn oil when I got it (BAD).Rebuilt engine .So I'm thing the CAT is  plug.And over 100,000 mile.
« Last Edit: May 17, 2010, 05:39:21 PM by airdale navy »
