Brake Problem....
  • 1854 Views
Offline Asbury030
  • 85
Brake Problem....
« on: May 16, 2010, 01:41:53 PM »
Ok well I put the Spidertrax E-Brake kit on my sammy... my brake light comes on even when I have the wire unplugged.... But also I dont have all my brakes installed could this be the issue? Or what is going on?
Re: Brake Problem....
« Reply #1 on: May 16, 2010, 05:44:38 PM »
Which brake light are you referring to?
The ones on the back of the car?  Those are controlled by a switch above the brake pedal
The idiot light on the dash?  You probably have a short (a pinched wire) somewhere or low brake fluid (some vehicles have a float switch in the MC wired to the same light).
« Reply #2 on: May 17, 2010, 12:23:49 PM »
I think the e-brake light requires the switch in the ebrake to be grounded instead of unplugged.
Since you don't have your brakes installed yet it might be the pressure switch in your brake master cylinder.
