soft top hardware?
  • 1883 Views
Offline crgm101
  • 80
soft top hardware?
« on: May 17, 2010, 12:20:38 PM »
i have been gathering soft top hardware for a while since my 87 suzuki samurai didnt come with a top or hardware i have the  bow and the 2 side rails just behind the front seats is there anything im missing. oh and the front bar above the window was already there
Re: soft top hardware?
« Reply #1 on: May 17, 2010, 12:22:11 PM »
On the back side of your targa bar is there the metal 'rails' that the soft top slides into?  They should be screwed into the targa bar.
Offline crgm101
  • 80
« Reply #2 on: May 17, 2010, 12:28:03 PM »
the 2 on either side that run from top to bottom yes held in with 4 screws each
Bobthebiker
« Reply #3 on: May 17, 2010, 12:30:11 PM »
there should be two little hooks on the inside of the truck at the back for the strap from the soft top to hook into as well.
Offline crgm101
  • 80
« Reply #4 on: May 17, 2010, 12:38:30 PM »
i havnt seen those yet does anyone know where to get the 2 little hooks
Bobthebiker
« Reply #5 on: May 17, 2010, 12:58:21 PM »
probably your best bet is either a partout, or you could PROBABLY make a set.  I could probably fab some up using mine as a template if you were interested,  it'd take a day or two to actuall make em cause I have everything like that welded at my friend's place.
Offline crgm101
  • 80
« Reply #6 on: May 17, 2010, 01:38:11 PM »
well my top will be here in a week and ill see if i can talk my freinds out of theres if not i will let you know appreciatte all the help can wait to not get soaked when it rains
