toyota axle ?
  • 2581 Views
Offline 87zukini
  • 35
toyota axle ?
« on: May 20, 2010, 05:06:05 PM »
ok guys im starting my toyota axles i have my front axle but its missing the hubs not just the lockouts but also the whole hub . im wondering if the ones from an ifs truck will fit on the solid axle spindles? im going to run 5.29 gears spool rear locker front and a high pinion. plan to run a 1.6 16v with the tracker 5spd and t-case in front of the samurai t-case . anyone running this how does the samurai case hold up?
thanks for any help
mike
Offline Amilla
  • 1076
Re: toyota axle ?
« Reply #1 on: May 23, 2010, 10:11:06 AM »
You can use some parts off of IFS Toyota's and widen your front end 3".
Here's a good kit if your interested.
http://www.sky-manufacturing.com/new/detaproduct.php?id=127
Amilla
Offline oneal
  • 38
Re: toyota axle ?
« Reply #2 on: May 26, 2010, 05:55:06 PM »
 It will hold up just fine.My old ride was a 93 kick,5:13 geared spooled D-44's,37" pitbull rocker's,homebrew dual case with 6.5 in the samurai case...Never could break it.What you need is a good mounting system coupled bucket style and you wont have to worry.
