Technical Discussion - Performance / Modify
leaf spring bushings
woof359
111
May 24, 2010, 12:42:04 PM »
well the front and rear leaf spring bushings come out like POLYURETHANE bushings ? or are they pressed in ? requiring them to be burned out ?
Last Edit: May 24, 2010, 06:37:09 PM by woof359
CHUCK AND MICHELLE
MadMaxZuki
77
Re: leaf spring bushings
May 24, 2010, 07:05:01 PM »
i assume they are the stock bushings and there is a metal collar in the leaf eye that needs to come out with the bushing. i pried it inward and used a press to get it out. you will need a press to get the rubber bushing out. also too cutting the collar in the space where the eye loops around will help too.
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
woof359
111
May 24, 2010, 08:11:24 PM »
thanks madmax, I was hoping they wernt pressed in but thats not the way my luck goes, I see some drilling and cutting in my near future.
CHUCK AND MICHELLE
doughboy0379
290
9
Blinker fluid is free so use it........
Reply #3 on:
May 24, 2010, 09:49:58 PM »
I beat mine out with a hammer and a chisel, sorry but at the time I did not have a way to cut or press them out so I went super cheap and used elbow grease lol oh and some WD-40 too
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds
woof359
111
Reply #4 on:
May 31, 2010, 08:14:10 PM »
all the leaf spring rubber bushing came out in 2 parts, the rear shackles were rusted solid but after slicing them off with a hack saw the rubber bushing just poped right out. man did I luck out.
CHUCK AND MICHELLE
