track/kick dual t case????
  • 9163 Views
« on: May 24, 2010, 08:34:32 PM »
has anyone done a dual t case set up in there track/kick??? if so how did u do it and can i see some pics....
Re: track/kick dual t case????
« Reply #1 on: May 24, 2010, 09:50:23 PM »
You asking about any dual tcase setup, or one in particular (like trackick/trackick, trackick/samurai, etc.)?  I know a few have done the trackick/samurai setup, but I don't know if anyone on here has that setup.
« Reply #2 on: May 25, 2010, 03:42:11 PM »
yeah i was wondering about trackick to any divorced t case such as the samurai t case. i was also wondering about drive shaft angles and how the divorced case was held up in the frame.
« Reply #3 on: May 26, 2010, 07:17:17 AM »
While I have never done dual tcases in a trackick...
I would think the rear dshaft angle might be kinda steep on a 2 door.
You would have to make new frame mounts to hold the new tcase, of course.
« Reply #4 on: May 26, 2010, 11:38:20 AM »
Check out the Kicker series from OTT Industries.  There is also the Shogun, by Rock 4X Fabrication, that allows you to combine your Tracker T-Case with a Samurai T-Case similar to the Kicker 3.
http://www.ottindustries.com/kicker3.htm
« Reply #5 on: May 26, 2010, 09:46:47 PM »
thanks for the help guys. i think if im gunna be doing this im gunna do my own thing not buy it. i saw this one picture online somewhere where the guy cut up the kick t-case removing the front output and made a plate to covor it. then he made a frame from t-case to t-case so the rear transfer case (samurai) was held up. seems to be not that tricky?? :P i just wonder how hard it would be to make the covor to covor where you cut...... hope this makes sence. here's a pic.
Offline 87zukini
  • 35
« Reply #6 on: May 28, 2010, 03:17:05 AM »
i am doing this mod this winter when i put in my 1.6 and im building it not buying
« Reply #7 on: May 28, 2010, 07:22:53 AM »
Do you know how you will be doing it???
« Reply #8 on: May 28, 2010, 07:38:27 AM »
Here is my DIY build that I did for a "kicker 3", "shogun", doubler, whatever you want to call it.
http://bbs.zuwharrie.com/content/topic,46349.0.html
