Are there any big bore kits for a 1.3 motor ?
  • 2081 Views
Offline bat333
« on: June 02, 2010, 11:46:13 AM »
I was just wondering if anyone makes a Big Bore kit for a 1.3 motor ?
Re: Are there any big bore kits for a 1.3 motor ?
« Reply #1 on: June 03, 2010, 05:36:31 AM »
Try Sammypro.com. If you have a 1298 then its not too difficult to swap to a 1324 but once you start spending money out on performance parts it soon becomes cheaper to do the 1.6 swap.
« Reply #2 on: June 04, 2010, 07:51:52 AM »
The 1.6L is a "stroker motor upgrade" to the 1.3, the bore is only 1mm
larger, but the stroke is 15mm longer, and gives about 30% increase in
power over the 1.3L engine, but there are clearance issues because the
1.6L engine is also about 1 inch taller
