Ebay ecu fix? scam or Real????
  • 2697 Views
Offline Alaska101
  • The Original !! What started it all.
« on: July 02, 2004, 04:54:28 PM »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7908058635&category=33596
Has anyone got this kit and what is it ? how does it Work? Anyinfo would be great!!!!
Free is better!!!
1979 Lj81 Truck. Named REP-TAR! (Green thing from the rugrats)
Mod's include:
2001 GV frame w/ 2.0l dohc, and auto trany
Snorkel, 31x10.5 R15 tyres, Soon to be 35's
, also will have a dump box!!
Offline Natebert
  • 1098
Re: Ebay ecu fix? scam or Real????
« Reply #1 on: July 02, 2004, 05:43:17 PM »
*GASP*
20 bucks for a capacitor and pictures?
daaang.
My local radioshack sells those for a lot less.
Good luck.
~Nate
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: July 02, 2004, 06:55:48 PM »
take your old ecm apart.  odds are you'll be able to see the part physically damaged - burned out. Or you could do it his way, should work fine.
Offline Alaska101
« Reply #3 on: July 03, 2004, 10:05:19 AM »
THEY SAY YOU DO NOT HAVE TO OPEN UP THE ECU??? HOW DOES THIS WORK???
Mod's include:
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #4 on: July 03, 2004, 02:21:27 PM »
It doesn't.  You must take it apart.  My mechanic took it a TV repair shop to get it fixed.  Cost me $160.  Better then $800 for a new ECM.
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #5 on: July 04, 2004, 12:24:47 AM »
I say look around online and you can most likely find out how to do it for free.  If it is just instructions that you need it is probably out there.
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
« Reply #6 on: July 04, 2004, 09:21:54 AM »
I know I've said this before but I will keep saying it. Unless you have the proper working environment for working on electronics you risk damaging it. All modern electronics is static sensitive, you can carry thousands of volts of charge in a field around your body. The FSM tells you not to touch the pins but once you open it it is far more likely to be damaged. It is unlikely to fail straight away but its life may be seriously reduced. Taking it to a radio shop is a good idea.
