Quick SAS Question
  • 2402 Views
Offline explosivo
  • 3157
Quick SAS Question
« on: June 03, 2005, 09:42:01 PM »
For those who've done an SAS in a Trackick, what did you do about the rear A-arm mount? From what I can tell with lining everything up, it's going to be in the way of the driveshaft on articulation. Did anyone have an issue with this?
omghi2.us[/url]
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: Quick SAS Question
« Reply #1 on: June 03, 2005, 10:11:31 PM »
i've seen some sas conversions, and they actually cut out the cross member altogether. this leaves more room for links and driveshafts. a custom cross member was fabbed up for chassis stiffness.
Offline mesjr2004
  • 422
« Reply #2 on: June 04, 2005, 02:30:04 AM »
yep cut that sucker out . and put one in the front under the oil pan .
Offline Natebert
  • 1098
« Reply #3 on: June 04, 2005, 04:12:29 AM »
Depends on the lift!
We took the Arm off, but left the cross member.
(We're too high off the ground to worry about that cross member.)
Offline mesjr2004
  • 422
« Reply #4 on: June 04, 2005, 05:37:29 AM »
your running a kicker 3 too , that mite help by moveing the driveshaft back away from the crossmember , but id think its still pretty close, isnt it ?
Offline explosivo
  • 3157
« Reply #5 on: June 04, 2005, 08:44:50 AM »
You happen to have some pics of how you did your crossmember, mesjr2004?
omghi2.us[/url]
