yj spring bushings
  • 1603 Views
Offline igaug
  • 40
yj spring bushings
« on: June 07, 2010, 03:28:30 PM »
im trying to get the old bushings out of my yj springs and am having some trouble. the smaller end i was able to pound out with a hammer, but the larger end with the metal sleeve over the bushings is not budging on any of the 4 springs. all four came out of the others though. anyone have any advice? also im in the process of turning the center spring alignment pin around and one is toast, anyone know where i can get another one? thanks guys
Offline dupont#24
  • 48
  • Deer hunter
Re: yj spring bushings
« Reply #1 on: June 07, 2010, 06:31:13 PM »
I will tell you what I done somebody else may have a better suggestion I took a small  drill bit and drilled all the way around the steel bushing into the rubber .This will loosen it up enough that it should come out with a little help with a hammer then and a screwdriver.
