Fuel problems??? Maybe.....?
  • 31 Replies
  • 8178 Views
0 Members and 13 Guests are viewing this topic.
Offline jerryp58
  • 449
Re: Fuel problems??? Maybe.....?
« Reply #15 on: June 29, 2004, 04:07:58 AM »
already checked the injectors. Nothing there.
When you say "nothing there" you mean problems, not fuel, correct?
How about the O2 sensor(s)?
Jerry
Offline Speedracer7c
  • 2210
« Reply #16 on: June 29, 2004, 09:52:57 AM »
I thought it might be the o2 sensor, I"m going to unplug that and see what it does.
  • 2210
« Reply #17 on: June 29, 2004, 09:59:06 AM »
Nothing with the o2 unplugged. Didn't trip the CEL either so who knows.
  • 2210
« Reply #18 on: June 29, 2004, 10:03:34 AM »
try to see if a 8 Valve and 16V fuel pumps are the same. if so george has a bunch of pumps.
stu
K cool. Priced out a new pump 105 bucks and new pressure regulator is 160....this sucks.
« Reply #19 on: June 29, 2004, 11:36:07 AM »
The symptoms you have are classic low
fuel pressure, check the filter, and the
fuel PSI, both at idle and trying to drive,
see what happens, My vote is for the
Regulator, fuel PSI should be around
36-43, 36 is correct for TBI systems, I'm
not sure if the MPI system is higher or same.
A quick regulator test is to pinch shut the
return line and see if it runs better, might
not need to pinch all the way as it might
cause it to stall instead of idle.
« Last Edit: June 29, 2004, 11:37:55 AM by wildgoody »
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #20 on: June 29, 2004, 12:33:05 PM »
I was just wondering how one might go about measuring the fuel psi, is there a gauge or something?
steveo
  • 2210
« Reply #21 on: June 29, 2004, 01:42:45 PM »
I just pulled the tank out and pulled the pump doesn't seem like its bad, the bottom of the tank is clean as a whistle and so is the pump. GOing to goto the junk yard get a pump and a regulator see if that solves anything. Thanks for all the help guys.
« Reply #22 on: June 29, 2004, 02:26:36 PM »
Getting the fuel PSI is kind of a pain,
you got to tap into the pressure side and
put a guage on it, any guage that reads
to about 50-100 PSI should work but getting
it hooked up is the trick, you might be able to
get a fitting that will fit the threads between the
steel line from the tank and the flex line that
goes to the TBI then you could run a line to a
guage and see what you got.
If I remember right the rail on a 16V has a
PSI port that should be easier to hook up to
  • 2210
« Reply #23 on: June 30, 2004, 10:24:28 AM »
WEll i got a pump coming tomorrow, see if that does anything then if its still acting up i'm going to put in a new pressure regulator. Then if that doesn't fix it i'm taking it to a garage cause i have to have my car.
« Reply #24 on: June 30, 2004, 11:20:11 AM »
DUDE !!!!  Your blowing dough before
you know what the problem is, did you
try the pinched line to test the Reg ??
don't just throw $$ at a problem and
hope it's going away, figure it out and
fix it properly  :(
  • 2210
« Reply #25 on: June 30, 2004, 12:15:58 PM »
Free pump, so im' not throwing money at it. I'm gonna put that in,  Then i'm going to do the pinch test. THe pump doesn't look bad I just thought I would try it while the tank is out. Its probably something stupid that I just don't have the know how to figure out.  :-/
Offline idaholwb
  • 772
« Reply #26 on: June 30, 2004, 01:01:43 PM »
 Not sure why, but the computer being bad seems very likely.
Just trying to help.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #27 on: June 30, 2004, 03:11:31 PM »
Thanks Wild! More things to try and hopefully not break 8)
steveo
  • 2210
« Reply #28 on: July 02, 2004, 02:16:25 PM »
Put the new pump in, runs much better, is almost driveable on the street. But it still has absolutely no low end power until its up above 3 grand then it comes on ok.... The pedal feels weird, it pulls harder if you push it lightly then if you floor it. So that part is confusing me, I think i'm going to break down and take it to a shop.  :-/
  • 2210
« Reply #29 on: July 02, 2004, 02:45:55 PM »
What if it does nothing when you pinch the line???
