used gears diff/trans case
  • 1803 Views
« on: June 12, 2010, 10:56:16 AM »
looking for a set of 5:83-1 diff gears and a set of 4:24-1 trans.case gears for a 1992 tracker if anyone has stock??
Re: used gears diff/trans case
« Reply #1 on: June 12, 2010, 07:45:08 PM »
I have those, what did you have in mind?
« Reply #2 on: June 12, 2010, 08:46:00 PM »
well i swapped a auto 3 spd into my std chassis with 5:12s and i am running 31s on it, i was thinking to swap in 5:83s to see if it would give me better hi/lo running but was also thinking of puttung the 4:24-1 reduction gears set into the trans.case, what do you think would be my best bet, what would the cost be on the gear sets??
« Reply #3 on: June 12, 2010, 11:37:55 PM »
You will get a major reduction with the gears installed, I went from
23 MPH at 6K RPM in 1st gear to 21 MPH at 6K RPM in 3rd gear, and
that is with 33" Swampers
I want to go with a Undertaker instead
PM Sent
« Last Edit: June 12, 2010, 11:39:39 PM by wildgoody »
