samurai wipers loading battery/not working
  • 2045 Views
Offline papa smurf
« on: July 04, 2010, 01:01:57 PM »
87 model.
multi function wipers.
on any speed, and aslo if you pull on the switch to use the washer pump, it will put a load on the electrical system.
i have an accurate voltage gauge in the truck and it will pull it down to 10 volts while the system is on.
turn off the switch, and its back to normal voltage.
i can hear a click under the dash or in the column when i use the windshield washer, but nothing comming from the wiper motor.
im new to zuks and wasnt sure if this is a common issue.
ive searched, but cant find much.
see a lot of talk about the whole wiper switch/turn signal switch system. hope i dont have to replace it.
havent had time to search the issue further. i wanted to get some opinions before i tore the dash or the steering column apart.
thanks.
TJ
87 hardtop
11" lift on 32" swampers
transfer gear, and some other goodies.
Offline MadMaxZuki
  • 77
Re: samurai wipers loading battery/not working
« Reply #1 on: July 05, 2010, 03:42:14 AM »
my wipers were rusted on, you should take the windshield off and take the wiper arms off and lube the whole system w a god teflon or graphite lube.
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
« Reply #2 on: July 05, 2010, 11:14:13 PM »
If you unplug the motor do you still see the voltage draw?  You might just have a bad motor.
