COMPLETE ACME 1.6 NA DIESEL INSTALL KIT, NEVER USED $1600
  • 2043 Views
« on: July 10, 2010, 12:24:28 PM »
Everything you need to install a 1.6 NORMALLY ASPIRATED VW diesel in a Suzuki Samurai. except the clutch assembly and water hoses
This is a genuine ACME ADAPTERS kit.
It's never been installed but is shop worn, (dusty, chipped powder-coat).
All parts are new as supplied by Jeff at ACME, and some he supplies used.
Unless marked as USED, items are new and unused.
WHAT IS INCLUDED:
A 3/8" Heavy duty engine to trans.adapter plate, (ACME)
Flywheel machined ready to bolt on (ACME)
Engine bolting hardware kit (ACME)
Engine mounting brackets (includes clutch bracket mount)(ACME)
Alternator bracket (allows the use of your original Suzuki alternator and brackets) (ACME)
Throttle Cable (ACME SUPPLIED)
1.6 Angled oil filter adapter (ACME SUPPLIED)
Installation instructions with detailed color photos (ACME SUPPLIED)
26" VW radiator (NEW)
VW expansion tank with mounting bracket.(USED)
Water to oil cooler, (USED)
Exhaust manifold (USED) (ACME SUPPLIED)
Intake manifold (USED)
Diesel fuel filter housing (USED)
Wiring kit with diesel glow plug relay (ACME SUPPLIED)
Gear reduction starter (NEW)
Down pipe with braided flex coupling (ACME SUPPLIED)
OEM timing belt and tensioner, (NEW)
Water pump, (NEW)
Thermostat, (NEW)
WON'T BREAK UP KIT, AND WILL ONLY RESPOND TO PHONE CALLS
Price is firm as this is $300- $400 less than current replacement value, and that is not including shipping costs you would have, I can ship it and would likely be less expensive than if from ACME.
These kits are registered by ACME, so they should transfer support services to the new owner.
NEVER been used or installed!
Jim 510-542-8999 (Northern California)
Re: COMPLETE ACME 1.6 NA DIESEL INSTALL KIT, NEVER USED $1600
« Reply #1 on: September 15, 2011, 09:04:14 AM »
did you ever sell this?
thx
gord
parallax|removethispart|@vianet.ca
