i need torques specifications
  • 1899 Views
Offline paps133
  • 166
  • make your own road..
« on: June 29, 2004, 02:13:38 PM »
hey guyes i changed my brake tonigh and i needed to know what the torques specs for the caliper mounting bolts. thanks pierre
Offline Whipp
  • 62
Re: i need torques specifications
« Reply #1 on: June 30, 2004, 08:25:28 AM »
For what vehicle?
For a 1989 2 door 4x4 sidekick, the caliper pin bolts are supposed to be torqued betweeen 16 and 23 lb-ft.
- Craig
1989 Sidekick with 3" Calmini suspension, Old Man Emu Struts, Calmini header and exhaust combo, A/C on board air.
- Sold to my brother!
Offline jerryp58
  • 449
« Reply #2 on: June 30, 2004, 10:34:27 AM »
Wow!  This is horrible.
I tried to look this up in my 1990 Geo Tracker Service Manual.  I couldn't find the torque specs on the caliper mounting bolts.  The spec on the caliper pin bolts is listed as 65 ft-lbs.
Then I looked in my Haynes Manual for 1986-1993 Samurai, Sidekick and Tracker and found 29 to 43 ft-lbs for the caliper "holder" bolts (which I'm assuming are the "pin" bolts) and 36 to 57 ft-lbs for the caliper mounting bolts.
These two manuals are really falling short in this department :o
Jerry
Offline Whipp
  • 62
« Reply #3 on: June 30, 2004, 11:05:21 AM »
That is quite a difference!  I got my value from the 1989 Sidekick Factory Service Manual.
- Craig
Offline idaholwb
  • 772
« Reply #4 on: June 30, 2004, 01:06:53 PM »
 Not sure, but I always turn the bolts with a 3/8" drive Craftsman(brand not specific, just a size reference) ratchet just a little past snug. Tap it with the palm of your hand to a firm stop.
That's just I do it, hope that helps.
97 Sport
265/70-16s
2" lift
2.0 swap
