fuel pump
  • 2143 Views
Offline cavemann
  • 9
  • Stock '90 and HIGHLY modified '88.
fuel pump
« on: July 13, 2010, 06:54:49 PM »
Anyone have suggestions on an economical replacement for a '90 Samurai electric fuel pump? Maybe an inline pump? Don't know if it would have the right pressure. I've also heard of an identical pump for another application that's a lot cheaper. Any input is appreciated.
Re: fuel pump
« Reply #1 on: July 13, 2010, 07:02:43 PM »
You just need 36 PSI for that TBI system, any fuel pump
that can do that and fit should work. Many EFI systems run
at 43 PSI so keep a look out for what will work.
I used a Bosch fuel pump from an older CIS type system on
a VW or Porsche, worked fine and fit in easy
Offline cavemann
  • 9
Re: fuel pump
« Reply #2 on: July 13, 2010, 09:22:52 PM »
Thanx for the know. I'll see what I can find tomorrow.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: fuel pump
« Reply #3 on: July 17, 2010, 02:08:17 PM »
any inline electric pump that runs 3-7psi would work.  (thats for older carb samurai check your years specs.) I know most autoparts stores sell them for 30-50 bucks.
Re: fuel pump
« Reply #4 on: July 17, 2010, 04:14:48 PM »
A 90 samurai is EFI, so it requires a high pressure fuel pump.
Here is a link to a list of compatible pumps.....
http://bbs.zuwharrie.com/content/topic,70267.msg766424.html#msg766424
