90 tracker transmission help
  • 2406 Views
Offline inchaos10
  • 162
« on: July 15, 2010, 05:27:07 AM »
I have a 90 geo tracker with a bad automatic transmission. Does anyone know who sells master rebuild kits for it or could i buy a transmission from another year tracker/sidekick that would fit?
Re: 90 tracker transmission help
« Reply #1 on: July 16, 2010, 08:20:03 AM »
Do a google search for rebuild kits.  A trackick 3 speed auto tranny is the same as a TH180 tranny.  So look for kits for those trannys.
All 3 speed auto trannys that came in trackicks from 89-98 are a direct swap for yours.  Just make sure you get either a 2wd or a 4wd tranny....whichever matches yours.
« Reply #2 on: July 17, 2010, 01:34:28 AM »
Did they ever build a 2WD with an auto trans? I don't ever
remember seeing one
« Reply #3 on: July 17, 2010, 04:59:49 AM »
remember seeing one
Yep.  I've had, or have, a few 2wd autos.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #4 on: July 17, 2010, 02:06:19 PM »
remember seeing one
Yes, seen a few of them around here.   Also check craigslists for trannys.
« Reply #5 on: July 17, 2010, 08:04:25 PM »
I guess because the auto trans comes in the JLX model it's usually
equipped with 4WD also, but when the Trackers entered the market
I did see other builds that sort of didn't follow along with the Suzuki
badged trucks
Offline inchaos10
  • 162
« Reply #6 on: July 18, 2010, 05:58:36 AM »
Thanks for all the help. I found a rebuild kit locally here in florida. Any one know what gears i could put in the diffs to run 33"s. i want something thats good for on the road and offroad use. but more toward offroad part.
« Reply #7 on: July 18, 2010, 08:48:15 AM »
The best you can do in stock axle housings is 5.83s, and they are out of production
but I have a set I want to sell that have lockers installed in them
