HELP
  • 2735 Views
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
HELP
« on: July 22, 2010, 01:01:53 AM »
I need a distributor for my 92 sidekick 4 door with the 1.6 16v engine. Mine seems to have worn out. I have replaced everything but the rings and the pressures are good for all 4 mouse wholes. So, unless someone knows another reason why it would run great 1 min, bad the next and I have to keep resetting the timing...hook me up with a complete distributor!
THANKS MUCH.
Ben C.
541 409 1176
  ;D
The more it snows the happier I get!
Re: HELP
« Reply #1 on: July 22, 2010, 05:17:02 AM »
Have you checked your crankshaft pully for a worn or gouged out keyway? If someone removed the crank pully by removing the center bolt instead of the 6  8mm outer bolts, then replaced the crank pully and didn't torque it properly, you could have a loose pully, which would do what your describing. This is a common mistake when changing the timing belt, and results in a mangled keyway on the end of the crank, which in turn results in major timing fluctuations. Check it before you buy a distributor.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: HELP
« Reply #2 on: July 22, 2010, 06:38:57 AM »
bad caps in ECU...open it up and see if they've puked electrolite first =  FREE
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
Re: HELP
« Reply #3 on: July 22, 2010, 01:22:56 PM »
Had no clue and bet my mech didn't either...hes my nephew...will check that out as it has net run right sense we changed the belt!
Offline TNTracker
  • 37
Re: HELP
« Reply #4 on: July 22, 2010, 02:04:43 PM »
Had one with a bad keyway in the crank also could set the timing drive it a half mile and would start loosing power. Stop and check timing and it would be off again.
Re: HELP
« Reply #5 on: July 22, 2010, 09:04:22 PM »
x2.  I would guess the crank keyway is worn and the lower timing belt pulley is wobbling on the crank and that is why the timing varies.  And by "wobbling" I don't mean you can actually see it wobble front to back, it will be slipping back and forth around the perimeter of the crank nose.
Oh, and you will find there are only 5 small bolts that hold the crank pulley onto the timing gear.
Offline Daylight
  • 20
  • MISS MY ZUKIES!!!
Re: HELP
« Reply #6 on: July 22, 2010, 09:41:01 PM »
Ya, Nephue and I are both working to much this week to check but we talked and he thinks your right! Thanks Much all ;D . If this ISN'T it...I'll be back and u all can hit me with your next shot!
Re: HELP
« Reply #7 on: July 27, 2010, 04:20:30 PM »
Opps! Well, I knew there were SOME small bolts holding it on, and every time I do it it seems like a hundred they take so long to get right!
Re: HELP
« Reply #8 on: July 27, 2010, 04:29:02 PM »
Yeah, sometimes they are a PITA to get to and get out. ;)
