Calmini Rocker Skid Bars
  • 2434 Views
Offline 3xflyfisher
  • 9
« on: July 23, 2010, 11:34:28 AM »
Hey all,
I am looking to add some rocker panel protection to my Tracker and am looking at these because of the cost and also they don't appear to reduce the clearance as much as some of the other designs available.
I am curious if any one is using these and what are you impressions of them?  Do the attach to the frame and could they be attached with bolts rather than welding (not the best welder here!)?  Are "nerf" type bars a better bet for protection?  I do have 2" spacer kit (Jeff's) installed.
Any other thoughts, comments or suggestions?
Have a good weekend.
3xflyfisher
« Last Edit: July 23, 2010, 02:01:16 PM by 3xflyfisher »
'98 Tracker, Honda Ct-70's
Offline bush buster
  • 263
Re: Calmini Rocker Skid Bars
« Reply #1 on: August 01, 2010, 04:11:00 PM »
Here's a thread on DIY steel rockers.  You won't lose any clearance that way.
http://www.zukiworld.com/forum/build-diaries-how-to-diy/tracker-2x4-rockers-frnt-bmper-4-dr-sprngs-lwered-frnt-diff-$30-steel-frnt-diff/
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: August 02, 2010, 12:04:01 AM »
They only work if you have a 3" body lift installed.  MAYBE you could find a way around it, if you're up to fabricating different mounts, but if you're gonna go through that trouble, you should do what BRD HNTR did, they're much lower-profile and look great, IMO
BTW have fun with those Honda mini-trails.  They're a blast  ;D
Offline 3xflyfisher
  • 9
« Reply #3 on: August 02, 2010, 09:22:20 AM »
Hey bush buster and dj,
Thanks for the link to that thread - thats just what I wanted to learn.  I think that will become a project over the next month or so.
DJ - the little trail 70s are a hoot.  ;D  I currently have 6 ct70's, one sl 70 and two 50's.  One Ct is a 100 pt resto, one 50 is currently being restored, the sl and and another ct are running and original.  The others are future projects.  But now the track-kick addiction is taking over the honda addiction   ;).
Have a great day.
3xflyfisher
« Last Edit: August 02, 2010, 11:12:45 AM by 3xflyfisher »
