Gas lines
  • 1744 Views
Offline drenalin
Gas lines
« on: July 24, 2010, 04:32:39 PM »
I  am not sure which gas lines went were on my 97 x-90  ... i got the mainline right but what about the one beside it, where should that run to ?  what about the one coming from the small white plastic tank on top of the gas tank ?
 The one from the white plastic air tank goes to the canister up on the inner passanger fender under hood.... if that one is right than the other two must be because she runs , just not real good, still skjipping.
« Last Edit: July 24, 2010, 06:02:21 PM by drenalin »
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Gas lines
« Reply #1 on: July 26, 2010, 10:55:55 AM »
I dont remember even though I just did this myself when I bought a samurai (non complete) and they had put a FI body on a Carb frame.  There was one line that I didnt need to hook up but after a bit of running or driving the gas pressure would cause gas to spill out of it, so I plugged it and mounted the line on the firewall.  just be sure after you get it figured out if you have a line thats open to watch for that.
Offline drenalin
Re: Gas lines
« Reply #2 on: July 28, 2010, 07:00:20 PM »
Thanks ... i have it figured out , also put new plugs and wires on , works much better !
