transmission bolt torque???
  • 1704 Views
Offline cmatt1605
  • 51
« on: July 29, 2010, 12:58:54 PM »
i need to know what torque to put the bolts on the back of the transmission. (the rear part of the trans that has to come off before spiting the case) i know its not just tight, i tried that and it locked up the front shaft. does ANYONE know what torque it is? 10 ft lbs seems to be too much
Re: transmission bolt torque???
« Reply #1 on: July 29, 2010, 07:33:38 PM »
8mm studs? or takes a 12 mm wrench? 10 ft lbs is about right, or 8
but if it's locking up the front shaft, you have another problem in that
trans, better pull it back apart and check your work
Offline cmatt1605
  • 51
« Reply #2 on: July 29, 2010, 08:05:33 PM »
figured out the problem, while it was in the parts washer the reverse gear came loose and i did not notice the little wedge that had to go back in the grove, a slight turn of the gear fixed my issue and it all went together without any problems.
