Alternater voltage high 18+
  • 1973 Views
Offline airdale navy
  • 82
« on: July 29, 2010, 07:36:04 PM »
I'm have a problem with the 1.6 8V in my 91 sidekick.Its idling rough and running rough still about 2500 rpm then it seem to smooth out .I have put a new fuel filter .TPS , fuel injector (used) .35 PSI fuel pressure.New O2 sensor. CTS Checks out .IAT checks out. No vacuum leaks or exhaust leaks.Changed MAP (used) Tried a different  coil .Change the distributor.(used)New cap,rotor,wire.I recently rebuilt the engine .The only thing I found is the alternator voltage is 18 + volts. Could high voltage make it run rough?
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
  • 82
Re: Alternater voltage high 18+
« Reply #1 on: July 29, 2010, 07:38:56 PM »
No codes.
« Reply #2 on: July 29, 2010, 07:39:48 PM »
Ya, could fry computer parts too, as well as feeding too high
voltage as reference signals for the sensors
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #3 on: July 30, 2010, 05:53:29 AM »
Over charging well boil your battery and get acid on every thing I wound change it before I would start it again  till you change the altenator
  • 82
« Reply #4 on: July 31, 2010, 07:58:42 AM »
Bad volt meter reads 3.5 volts  higher than  should.Autozone checked the alternater Checked good.I will Start a new post I will have to reset TPS and recheck all the sensors.Any ideas would be helpful.
« Last Edit: August 01, 2010, 06:05:40 AM by airdale navy »
