New Project...need opinions
  • 15 Replies
  • 4157 Views
Offline MKW
  • 18
« on: June 01, 2005, 11:53:47 AM »
Hi all. Not only am I new to this forum, but I'm new to Zuks. I've been wanting to build a Samurai for a while and finally found one that is worthy (no rust). I have built a couple of Jeeps, but never a Sami. I have researched a lot of products and need some opinions. This vehicle will be used 90% on road, so I'm trying to build one that looks really cool, but will perform if asked. I want to run 33's. How much and which type of lift should I use?? I'd like to gear it using the T-case only, so which reduction set should I get?? Keep in mind that I'm most concerned about getting up to speed on the road. Thanks in advance for any help. Cost is not a huge concern, I just want it to do what I need.
Mike
Offline rockrat
  • 196
  • Got Ringr
Re: New Project...need opinions
« Reply #1 on: June 01, 2005, 12:02:37 PM »
Lift it using  a Trail tough YJ kit, run there Gear case gears and you should be good. I would recommend at least a 4:89 t-case gear set for the 33" with stock R/P. Although I would prefer to say even out your torque and accomidate both numericaly Higher R/P and a case gear. ( aleaviates stress) also if you are going to stay with Stock axles install some birf rings. Or you will break the Birfs under a 33 and a skiny pedal
Offline SnoFalls
  • 1358
« Reply #2 on: June 01, 2005, 12:47:35 PM »
I'll second that ... the YJ kit is a nice lift and the 4.89 is the tcase reduction you'll need. I also agree that getting the R/P ratio better is worthy (especially if you wanna add lockers as well).
« Reply #3 on: June 01, 2005, 01:18:12 PM »
Welcome aboard MKW
I'd hafta THird it cause I don't know anything about Sammies
But the info came from people that do. ;D
Offline rockrat
  • 196
  • Got Ringr
« Reply #4 on: June 01, 2005, 01:41:47 PM »
Welcome aboard MKW
I say nothing I hear nothing, And see nothing...
oh chit I did type something LOL..
Offline zukisuzi
  • 102
« Reply #5 on: June 01, 2005, 01:53:14 PM »
I'd do jus' like they said - YJ's w/ a 4 1/2" SPOA. Especially with mostly road driving, go with 5.13 or 4.62's to lower the driveline stress. (The TracKick front 3rd's will work in the Sami axles) Then you can get T/C gears if you decide you'll need 'em. And Birfield rings to manage the stress of the 33's. Have fun!  ;D
And welcome!
"I was so poor growin' up, if I wasn't a boy I'd've had nothin' to play with..."
--Rodney Dangerfield
Offline SidekickMN
  • 58
  • Waiting on  Money  for  Body Lift
« Reply #6 on: June 01, 2005, 02:56:42 PM »
ya i dont have a sammie but i would listen to them they know whats going on. welcome to the forum
1994 Sidekick, hard top, soft top, custom bikini top
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
Offline locjaw
  • 2045
  • 22
« Reply #7 on: June 01, 2005, 05:00:25 PM »
well I am runnin sammies and starting to move over to sidekick so you can probably immagine what my suggestion would be ;D
the sidekick just goes better with wanting to drive it on the road (comfortably)dont get me wrong man love what my sammy can do but the older I get the more i like comfort  ;D ;D ;D
jason
« Last Edit: June 01, 2005, 05:00:37 PM by locjaw »
Offline MKW
  • 18
« Reply #8 on: June 02, 2005, 04:17:46 AM »
So... the front third members from a trackick are 4.62's and will fit BOTH the front and rear axles in a Sami??? What year trackick should I look for?? Thanks...great info!
Mike
Offline locjaw
  • 2045
  • 22
« Reply #9 on: June 02, 2005, 04:44:14 AM »
you actualy only need the complete 3rd members and then you order a hybrid housing for therear and you use the entire 3rd member. on the front you take the gears out of the sidekick 3rd member housing and put them in the sammi 3rd member housing my sugestion would be 4.63 gears instead of the 5.12. the 5.12 's crawl real good but makes it a little to much gear for the street.
jason
Offline razorbak
  • 31
« Reply #10 on: June 02, 2005, 08:41:28 AM »
why do you need to take the gears out of the front third?
Offline locjaw
  • 2045
  • 22
« Reply #11 on: June 02, 2005, 09:38:18 AM »
because the samuri "chunk" is steel vs sidekick alumumumumin ;D
jason
Offline razorbak
  • 31
« Reply #12 on: June 02, 2005, 10:47:31 AM »
correct me if im wrong but isn't the rear aluminum as well?
Offline locjaw
  • 2045
  • 22
« Reply #13 on: June 02, 2005, 12:44:39 PM »
no both rear "chunks" are steel
jason
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« Reply #14 on: June 02, 2005, 02:48:34 PM »
You'll be fine with just the transfer case gears.
If you add gear reduction in both your transfer case and your third members, you'll be revving pretty high for 90% on road driving.
(voice of experience here, great around town but on the hiway at 4000 RPM with my whiny transmission I'm deaf by the time I get to the trail head )
87 Samurai
