Spare tire mount with 235s
  • 18 Replies
  • 4859 Views
Offline keith
  • 1176
« on: June 21, 2004, 01:36:47 AM »
When I put the 235s on my Tracker I didn't include the spare.  Yesterday I was looking at it's mount and it doesn't look like a 235 would mount to the stock carrier.  What are you guys doing to mount a spare other than getting Calmini's carrier.
Re: Spare tire mount with 235s
« Reply #1 on: June 21, 2004, 01:41:53 AM »
Is the bumper hitting the larger tire? I have a 33x12.50 hanging on my factory location, but no longer have the rear bumper
Offline keith
  • 1176
« Reply #2 on: June 21, 2004, 02:02:14 AM »
Yes, it is the bumper that would be in the way.
« Reply #3 on: June 21, 2004, 02:11:03 AM »
Sorry, can't help. I removed my stock bumper before I went with a larger spare. If you are not locked, you could use a smaller spare to get you back home.
Offline keith
  • 1176
« Reply #4 on: June 21, 2004, 02:24:41 AM »
What exactly would a locker do in this situation?
Offline Cwkick
  • 888
« Reply #5 on: June 21, 2004, 02:48:46 AM »
Okay,  Before you yell at me this is a Jeep part, but I think it will work.
It is a spare tire relocation bracket.  It moves the spare up and out a little.  Quadratec sells them.
Cwkick
« Reply #6 on: June 21, 2004, 03:02:26 AM »
If you have different size tires on a locked axle, it (the locker) will think you are in a constant state of wheel spin. Causing it to lock and unlock constantly and trashing your locker,axle, etc... Whatever breaks first :o
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #7 on: June 21, 2004, 04:05:05 AM »
i cut the part of the spare tire mount off that holds the tire asnd welded it back on further up and further out.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #8 on: June 21, 2004, 08:08:23 AM »
I've seen some nice fab work on custom spare swing arms and the like.... if you're into that sort of stuff. When I consider moving to larger tires, I'll do mine just like Heather's rig. It's a nice setup and I have a friend that will do the fab. work for me!
steveo
Offline bkcraun
  • 22
« Reply #9 on: June 21, 2004, 08:24:37 AM »
Relax, the 235 will fit fine on the stock mount. Looks like it's sitting on the bumber but my tailgate opens and closes fine.
Offline Urban_offroad
  • 47
« Reply #10 on: June 21, 2004, 10:53:01 AM »
BK is correct 235 will mount no prob, I had 30x9.5 on stock rim and on stock mount, all I had to do was reverse mount the tire on the mount (less of an offset) and space it out a bit.
Offline 1bigtracker
  • 3409
« Reply #11 on: June 21, 2004, 12:06:26 PM »
i had my 34/9.50 spare on a home made, extra heavy duty, huge backspaced rim.  it cleared the bumper fine but did a number on the tailgate.  then i backed into a tree with it soo i got a new one and took the rack off.
stu
Offline 1bigtracker
  • 3409
« Reply #12 on: June 21, 2004, 12:07:45 PM »
OHHH  I forgot i have a 3in body lift.  my bad,  never even crossed my mind.  but that 235 should still fit fine.
stu
« Reply #13 on: June 21, 2004, 12:33:03 PM »
I thought I put a 235 on my spare rack
when I was stock and I never remember it
hitting, it is like 1/4 of an inch from the bumper
tho, but fits fine, the little rubber stoppers on
the gate seem to get squeezed hard, I think
I would remove them, BTW I have a 33 12.5
swamper on the stock rim and on the rack, it's
a bit of a squeeze to get it on, but it fits  ;D
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #14 on: June 21, 2004, 03:46:16 PM »
MY 31" HIT THE BUMPER SO I SET THE WHEEL HOLE UP ON TOP OF THE THREADS & MADE A METAL STRAP TO HOLD IT ON....JUST DRILLED TO HOLES IN METAL STRAP TO GO OVER THREADS & BASICALLY PINCHED IT ON THERE...WILL TAKE PIC. TOMMORROW MAYBE IF I HAVE TIME.....GOT ME TO GONZOOKIN & BACK  ;) MATTY D.  8)
