Idling Problems Help!
  • 2069 Views
Offline mugen320
  • 14
« on: August 02, 2010, 08:08:07 AM »
My 1993 Suzuki Sidekick with 8 valve will only stay running when you give it gas.  The Engie will not idle on its own. Please if anyone has run into this problem before any insight would be helpful... ???
Re: Idling Problems Help!
« Reply #1 on: August 02, 2010, 10:00:08 AM »
There are several things to look at, check the hose that goes to the MAP sensor, it's the flat
black box with wires next to the battery, then check the TPS adjustment, but I think you
might just have a problem with either the throttle "kicker" , it's the vacuum controlled thing
on the back side of the TBI unit, and is supposed to open the throttle a little for something
like electrical load or cold start, I'm not sure, I took mine off, then you might just need to turn
the idle screw up a bit to get it idling at about 800-900 RPM.
The kicker on my truck was causing a random high idle situation, so I pitched it, no A/C and it
seems to idle ok with the headlights on so it's not a critical part in my book
« Reply #2 on: August 03, 2010, 11:09:38 AM »
I think you might just have a problem with either the throttle "kicker" , it's the vacuum controlled thing
like electrical load or cold start, I'm not sure, Wild
Cold start, the Idle Speed Controller should compensate for electrical load.
Do you have the Check Engine Light on? if so then you need to pull the codes. If not then I would start by checking the basics first including spark plugs, wires and dizzy cap. Check all the vacuum pipes for pinholes or splits.
