CB antenna
  • 2857 Views
Offline smife
  • 179
CB antenna
« on: August 03, 2010, 07:49:38 PM »
Do anyone know about CB's? Can I mount a fiberglass antenna inside my Tracker and still get reception? As far as I understand I should get reception maybe not miles away but, I should get some, right? Or should I just mount it to the outside?
Re: CB antenna
« Reply #1 on: August 04, 2010, 05:32:27 AM »
Mounting it inside the cab will greatly reduce your transmitting and receiving capabilities. If you just don't want one mounted to the Tracker full time, I would recommend getting a good magnetic mount CB and put it on your targa bar when you want to use it.... a good one will stay put with the soft top on up to about 60-65 mph. You best reception will come from a good permanent mount antenna.
HTH,
Offline grats
  • 28
Re: CB antenna
« Reply #2 on: August 04, 2010, 09:22:33 AM »
And as the old saying go's "you get what you pay for". Invest in a good outside mounted antenna
or your just wasting your money.
1982 SJ410
1997 Tracker
2008 SX4
Offline Jluck
  • 1389
  • 40
Re: CB antenna
« Reply #3 on: August 04, 2010, 10:37:22 AM »
Re: CB antenna
« Reply #4 on: August 04, 2010, 12:07:28 PM »
It would allow you to have an invisible antenna and not have it wreck the lines of the vehicle.  :)
Offline smife
  • 179
Re: CB antenna
« Reply #5 on: August 04, 2010, 12:14:09 PM »
I thought I'd put it inside to keep from breaking it on tree limbs. Alot of the trails we go on are pretty tight. And like Drone said, my Tracker is to damn sexy to trash it up with a three foot black antenna :laugh:
Offline mattstracker
  • 43
Re: CB antenna
« Reply #6 on: April 06, 2011, 04:51:13 PM »
you can get a 3' or 4' steel whip an mount it on the spare tire carrier. they have plenty of bend.
Re: CB antenna
« Reply #7 on: April 07, 2011, 04:11:19 PM »
Using a spring in the mount helps ALOT when playing in the trees...
Offline beagle..t
  • 1239
  • 16
Re: CB antenna
« Reply #8 on: April 07, 2011, 07:53:57 PM »
i made a mount for a 3'whip but havent bought the whip yet and its off the spare tire
