4dr center console ideas
  • 10 Replies
  • 3521 Views
Offline RJkick
  • 634
« on: August 04, 2010, 12:30:21 PM »
I have a '92 4dr and the center console is falling apart slightly
it has the 2 power window switches and e-brake and a small compartment
I was thinking of a way to put a cup holder or something in place of the small compartment
Then I thought why not ask what others have done
Any mods to the center console or swaps?
Re: 4dr center console ideas
« Reply #1 on: August 04, 2010, 03:46:06 PM »
Some models just have a cover that goes over the emergency brake.  If you don't mind loosing the power window controllers you could switch over.
Offline Jluck
  • 1389
  • 40
« Reply #2 on: August 04, 2010, 04:31:33 PM »
Try one from a two wheel drive. Has dual cup holders you could add your power switches. 8)
« Reply #3 on: August 05, 2010, 07:37:56 AM »
It's just not 2wd ones.  The cupholder consoles (2 cupholders) can be found in 2wd, 4wd, 2 door, 4 door trackicks....some have the power window switches, others don't...but it isn't hard to cut the hole out to add them.
Offline RJkick
  • 634
« Reply #4 on: August 06, 2010, 10:53:58 AM »
Thanks
I'll keep an eye out for a used one
Does anyone know if Low Range, Hawk, or anyone sells them?
« Reply #5 on: August 06, 2010, 11:04:54 AM »
Here is what the cupholder consoles with the power window switches look like....
Offline RJkick
  • 634
« Reply #6 on: August 09, 2010, 01:04:38 PM »
perfect
now I just need to find one
Thanks
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #7 on: August 09, 2010, 04:41:30 PM »
I found one at my local wrecking yard from a 4dr Sidekick Sport.  But I didn't get it because of the window switches (I would have to blank those off for my 2dr) and someone used long wood screws to mount it, which ended up putting 6 extra holes in it.  But I noticed that I couldn't mount it in my 2dr because it didn't have the brackets in the floorboard to mount it.  Anyone else notice that?
« Reply #8 on: August 09, 2010, 04:46:15 PM »
Yeah.  You have to get the brackets along with it.  The brackets will fit in trackicks that didn't originally have the big consoles in them.
Offline djlantis57
  • 871
« Reply #9 on: August 09, 2010, 07:30:31 PM »
Are they welded in place or is there a hole there that a bolt fits through?  I never looked into it, I just assumed it wouldn't fit
« Reply #10 on: August 09, 2010, 07:32:31 PM »
The brackets bolt to the top of the tranny tunnel.
