Replacing wheel studs
  • 11 Replies
  • 4470 Views
Offline keith
  • 1176
« on: June 18, 2004, 06:04:37 AM »
In replacing my tires somehow a wheel stud broke off.  Sears claims it was crossthreaded when I put the wheels on.  They did the balancing of the tires.  In a previous post I found that it takes a #336 metric 10.9--12x1.25 37mm stud.  What is involved in replacing a stud on the rear wheel?  Also what is the danger of temporarily driving with 4 bolts?
« Last Edit: June 18, 2004, 06:17:27 AM by keith »
Offline jagular7
  • 1026
  • Jagular7
Re: Replacing wheel studs
« Reply #1 on: June 18, 2004, 07:07:28 AM »
Running around with only 4 bolt on a 5 bolt rim won't have a drastic change. It shouldn't be a problem.
Though I'd suggest when you have time, fix it.
Replacing it is rather simple, but time consuming. You will need to have room behind the flange to be able to press it out and press in the next one. A stud is a screw which is pressed fit into its location. There are longitudinal splines which hold the stud in it's location. So if you can press/push the bad one out with the axle in, then be able to press/pull the new one through, you won't have to remove the shaft.
Pressing the old out is the most of the work. Pulling one back through is the easiest. Once you get the old one out, you could press the new one in, or use a spacer and the wheelnut to pull it through.
Clear as mud?
Lenexa, KS
Offline xamtex
  • 72
« Reply #2 on: June 18, 2004, 11:55:50 AM »
just remove the rear drum and tap the broken stud out with a punch,fit new stud into hole and drive it into place with the same punch!easy!! ;)
god must love crazy people,he made so many of them!!!
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: June 18, 2004, 12:04:13 PM »
Wheel studs have a flange on them. This way you can't pull them out with over torqueing the nuts. You could use a punch, but it usually takes a good couple whacks of a 3.5# hammer to remove a stud. And this is on top of a bench and good layout for hitting it.
Lenexa, KS
« Reply #4 on: June 18, 2004, 02:59:50 PM »
I thought it was a 12 x 1.50 thread, check before
you put it in, like screw the lug onto the new stud
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #5 on: June 18, 2004, 03:48:56 PM »
I know the sammy's are 12x1.25 I believe the Kicks are the same.
   Nissan uses this thread pitch and most Nissans have very nice Cadnium plated lug nut on them.  Cadnium = Fancy factory chrome that doesn;t rust chip or peal like the aftermarket ones allways do.
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #6 on: June 18, 2004, 04:07:39 PM »
12x 1.25 is correct I just replaced some of mine.
Mac
« Reply #7 on: June 18, 2004, 04:08:44 PM »
OK, My cornfuzion
Thanks, I want to get some new
lugs, this will help   :)
Offline 1bigtracker
  • 3409
« Reply #8 on: June 18, 2004, 04:28:19 PM »
my studs are getting worn too.  in my case, dirt sometimes falls off the back of the wheel when putting it on the studs and it gets into the threads.  trying to wipe it off doesn't help much sooo :-/     good now i know what to order. thanks
stu
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #9 on: June 20, 2004, 06:12:27 AM »
Mac
Hey Mac, how much did you pay for your studs?  I'm going to need some this winter when I mount my winter wheels.
« Reply #10 on: June 20, 2004, 09:13:54 AM »
They are 12x1.25. You need to get the right overall length and the right shoulder length too. When we fitted my rear discs we replaced the studs for longer ones but we warned after we had knocked the original studs out the holes were too worn to fit the original diameter (shoulder) studs back in so we had to ream out and fit some with a slightly larger shoulder.
Offline keith
  • 1176
« Reply #11 on: June 28, 2004, 02:01:35 AM »
I got the studs from NAPA.  They were $1.60 each.  The chrome lug nug was $3.00.  To put them in all you have to do is take off the drum(not as easy as it sounds).  They pound right into it.  I'm not sure what fronts would require.
