can you put a 16v head on an 8v block?
  • 25 Replies
  • 11058 Views
Offline idaholwb
  • 772
Re: can you put a 16v head on an 8v block?
« Reply #15 on: June 25, 2004, 07:45:42 PM »
 She bought it with a bad head gasket.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #16 on: June 25, 2004, 08:04:44 PM »
Just to mention guys, this has been one of the most interesting threads I've read so far oddly enough... and I don't normally like the technical jabberwalkie. Hey, by the way, how do I know if I have a 16v or an 8v?? Yes, as I've mentioned before, I'm retarded with this stuff.
steveo
Offline idaholwb
  • 772
« Reply #17 on: June 25, 2004, 08:23:26 PM »
 Easily answered. If your engine has a steel valve cover and the spark plugs go in through the side above the exhaust manifold, you have an 8 valve.
If the valve cover is aluminum and the spark plugs go in from the top of the cover, it's a 16 valve.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #18 on: June 25, 2004, 08:39:09 PM »
Bah, it looks like I got an 8v.... thanks for the quick reply, just wonder though, should I be sad at this or happy? :-/
steveo
« Reply #19 on: June 26, 2004, 03:59:38 AM »
steveo
Well what Idaho said, and the big "16 VALVE" cast into the top
and on the Cam Cover  ;)
Offline idaholwb
  • 772
« Reply #20 on: June 26, 2004, 04:05:39 AM »
steveo
Obviously the 16v would have been nicer, but the 8v works just fine with a couple of tweaks.
Such as, a header, 2-2.5" exhaust, a K&N air filter, a hotter coil like the MSD Blaster2, and good spark plugs and wires.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #21 on: June 27, 2004, 09:32:26 AM »
Filter and exhaust I can do... what about a coil...whats that??
steveo
Offline idaholwb
  • 772
« Reply #22 on: June 27, 2004, 11:00:11 AM »
 On the distributor cap you have 5 wires, right? Well the 4 in the outter pattern go to the spark plugs. The one in the center goes to the ignition coil on the firewall. The coil is what makes the spark that the distributor sends to each spark plug. The stock 8v coil I think puts out about 15-25,000 volts. The MSD Blaster2 puts out like 40-45,000 volts. You get a cleaner burning more consistant running engine. The hotter coil really helps at lower RPMs and also at higher RPMs on the freeway.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #23 on: June 27, 2004, 04:55:17 PM »
Holy JEBUS! I had no idea that stuff like that was out there!!! Any other surprises for me?? I think I'll get one of those new coils A-sap! Thanks for the info! How much does one run ya?
By the way, I've noticed that you can swap the engine in Sidekicks from other posts and posts like this, so what options does a guy like me have? There are cheap wrecks all over Grande Praire, so I can find just about anything!
steveo
Offline explosivo
  • 3157
« Reply #24 on: June 27, 2004, 05:16:21 PM »
How hard are aftermarket coils to wire in?
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #25 on: June 27, 2004, 05:58:09 PM »
 Coils are pretty straight forward to wire in. The esiest way to wire one in, if you have the screw terminal version, is look at the factory coil top, I think it is marked with a + sign on one side, the aftermarket coil does too, just unscrew the nuts from the coil, pull off the ring connectors and transfer them over to the new coil and reassemble. Put the new coil into the old coil bracket, you might have to use a small thin strip of rubber to help fill in the extra room in the coil braket, and put it back on the truck. You're done. Start and enjoy.
But, if you have the square style coil, I'll have to get back to you on the wire up.
97 Sport
265/70-16s
2" lift
2.0 swap
