Build Order
  • 3012 Views
Offline whtboy333
Build Order
« on: August 10, 2010, 06:49:14 AM »
I recently bought a 93 tracker soft top 4wd.  It was pink, now camo in memory of my brother in law who was in the military and passed away 2 years ago.  I would like to do a decent build to the car, designing it more for mud then rock climbing.  I want to know what order to do things in, such as winch bumper suspension tires locker and more please give me some advice.
Thank You,
Matt
Offline my996duc1
  • 222
Re: Build Order
« Reply #1 on: August 10, 2010, 08:34:26 AM »
« Last Edit: August 10, 2010, 08:38:21 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Re: Build Order
« Reply #2 on: August 10, 2010, 11:32:08 AM »
Welcome to the board
First decide what size tyres you want/need then build the vehicle around that.
Offline whtboy333
Re: Build Order
« Reply #3 on: August 10, 2010, 01:31:17 PM »
Im Lookin at like a 30 or 31 max rather not have to do much a bodylift maybe 1"
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
Re: Build Order
« Reply #4 on: August 11, 2010, 06:05:10 PM »
I'm runnun 31's with 2" coil spacers, they rub the wheelwells when pushed right up, longer bumpstops would fix this for the back but I think the front will still rub at full turn, a 3"body lift should fit 31's, you might have to trim up the bumpers a bit. I have a 3" body lift that I'll be putting in soon, if I find it tipsy I'll take out the 2"coil spacers, if I do I'll tell if the the tires rub anywere. I'm also using stock gearing and you notice it in 4High when its in a fare bit of mud with the BFG km2's 31/10.5/15,M/T's, probable a 9.5wide tire or A/T's would be easier to turn with my 80HP! But you don't notice it in 2High.
This is what it looks like with 31's & a 2"lift... ;)
« Last Edit: August 11, 2010, 06:15:37 PM by Jordan »
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Offline jeff1997
  • 1228
  • 27
Re: Build Order
« Reply #5 on: August 11, 2010, 07:00:45 PM »
I can supply the 2" suspension lift.  ;)
3" Masterkit1 body lift
Custom strut spacers
Re: Build Order
« Reply #6 on: August 12, 2010, 05:37:14 AM »
I would suggest the following order...
1- Lift and Tires (if your shooting for 30-31 range, gearing should not be a problem).
2- Rear locker.
3- front locker.
4- more lift and bigger tires.
5- gears to match your new lift and tires.
6- gut it all and custom build a trail beast.
Depending on how hard you wheel your rig, somewhere in there you will need axle/CV upgrades (probably after 4) but if your easy on the gas, they can last a while.
Re: Build Order
« Reply #7 on: August 13, 2010, 02:14:29 PM »
2- Rear locker.
3- front locker.
I agree.
