motor swap 96 16v to 99 Tracker
  • 2717 Views
Offline smife
  • 179
« on: August 11, 2010, 07:42:30 AM »
What if anything needs to be changed to make a 16v out of a 96 Tracker work in a 99 16v Tracker. I know things changed in 99 but, I'm not sure on the motor. Thanks
Re: motor swap 96 16v to 99 Tracker
« Reply #1 on: August 11, 2010, 08:27:14 AM »
99 has the 2.0L doesn't it?  If so it would take a lot of work to swap it out, you would probably be better off getting a JDM 2.0L or finding a 2.2 or 2.3 to drop in it.
Offline smife
  • 179
« Reply #2 on: August 11, 2010, 11:09:06 AM »
I don't know? I just had a guy call me looking for a 1.6 16v for a 99 2 dr. Tracker. I told him I had a 96 16v motor but I wasn't sure about the ?interchangability?  ???
Offline sirmasterj
  • 8
« Reply #3 on: August 11, 2010, 11:16:05 PM »
if your both of your tracker's are 5 speeds there isn't much to change.  I have an 89 tracker 5 speed, a 91 sidekick auto and a 99 tracker auto.  The 99 tracker's came with at least 2 motor sizes.  One being the 1.6l 5 speed only, 2.0l auto or stick and a 2.5l auto or stick.  There might be the odd modification like cap and rotor versus a coil.  The rad mounts a little differently.  I will check the differences between mine and let you know tomorrow if I find anything else.
Offline smife
  • 179
« Reply #4 on: August 12, 2010, 12:03:20 PM »
Thanks looking forward to it
