Budget Lift Q
  • 9 Replies
  • 2752 Views
Offline 92Sidekick4x4
  • 1456
Budget Lift Q
« on: June 02, 2005, 11:40:33 AM »
Hey everyone, i know that this has been covered a few times but i cant seem to find the threads,
right now i have a 3" body lift and im wanting to put in some 2" coil spacers
i think i have almost everything soreted out, strut spacers, rear shocks etc. but the one thing im not sure about is brake lines am i going to have to do anythign with them? (extend etc.)
or if you guys see anything else that i may encounter it woudl be awesome if you said somethin ;) :) thanks
Offline Fity
  • 49
Re: Budget Lift Q
« Reply #1 on: June 02, 2005, 11:45:08 AM »
Your brake lines should be fine.  The front ones will extend beyond the point of the CV's and the rear is good for more then a 2" lift, I have a 6" lift on the rear of mine and it just long enough.  :)
  • 1456
Re: Budget Lift Q
« Reply #2 on: June 02, 2005, 12:05:13 PM »
k cool, what lift do u have?
  • 1456
Re: Budget Lift Q
« Reply #3 on: June 02, 2005, 01:55:20 PM »
any advice from anyone else?
Offline adamd
  • 369
  • sofa king we todd it
Re: Budget Lift Q
« Reply #4 on: June 02, 2005, 02:33:54 PM »
I would go 1 1/2 in the front.
'98 kick
3" B/l
30" Mud Kings
Re: Budget Lift Q
« Reply #5 on: June 02, 2005, 02:55:02 PM »
I just bought the longer rear brake line from Calmini
and for more Info see Heathers budget lift
http://www.zuwharrie.com/content/view/11/27/
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
Re: Budget Lift Q
« Reply #6 on: June 02, 2005, 11:38:51 PM »
What we usually do here is to relocate the brake line hose (just on the front left side) by drilling a new hole on the body to keep the brake line lock in the stock position.
I haven't done it on mine (tho I only have a 2" BL) but when I have the time I'll get it done.
I've been running for a while now without relocating but I just want to be on the safe side that's why I'll still relocate. Also a friend told me the reason there's a lock there is to keep the stress on the brake line evenly distributed (at the connection to the body & the lock vs. just the connection to the body)...
Did I just explain that clearly? I'm not sure if I understand what I just described ;D
[/url]
[/url]
Offline Natebert
  • 1098
Re: Budget Lift Q
« Reply #7 on: June 03, 2005, 05:46:27 AM »
  • 1456
Re: Budget Lift Q
« Reply #8 on: June 03, 2005, 05:53:17 AM »
ah, thanks nate :D
Offline Natebert
  • 1098
Re: Budget Lift Q
« Reply #9 on: June 03, 2005, 05:54:40 AM »
The fronts will be fine, you might want to unclip them from the strutt.
The rears will probably be fine too.
I don't think we extended ours until we lifted it up 3 inches or more AND extended the wheelbase.
You might be able to get away with just reloacting the mounting bracket on the frame.
