death wobble on a 97 sidekick?
  • 3640 Views
Offline safarikick
  • 270
  • nor-cal rhinos
« on: August 12, 2010, 06:05:44 PM »
i got a death wobble on a 97 sidekick. i have the Sidekick Extreme Duty Idler Arm. the sidekick has the 3in lift kit from calmini
Re: death wobble on a 97 sidekick?
« Reply #1 on: August 12, 2010, 08:50:52 PM »
What size tires? have you checked the steering linkage yet?
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #2 on: August 12, 2010, 08:56:17 PM »
32 and i have put 2 used  center links in. balance all the tire
« Reply #3 on: August 13, 2010, 03:37:18 AM »
Alignment? Had it checked?
« Reply #4 on: August 13, 2010, 08:45:31 AM »
It's the center link, the problem is it want's to rotate and causes
the truck to dart from side to side when the tire hits something, as
far as the wobble, I've never had that happen, but if the link is worn
enough it could I guess. The alignment could be the problem too,
depending on the road surface as it pulls left and right.
How much and what kind lift do you have?
« Reply #5 on: August 13, 2010, 01:44:44 PM »
We added a steering brace for the passenger side on Project Trouble, not sure if this is what wildgoody is referring to as going bad:
« Reply #6 on: August 13, 2010, 03:07:01 PM »
No, the center link is what the tie rods connect to, but you
have a valid point, if the idler is loose it could cause problems to.
You might want to have someone crank the steering wheel left
and right while you watch the steering parts for odd movement
« Last Edit: August 13, 2010, 03:08:44 PM by wildgoody »
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #7 on: August 13, 2010, 08:34:00 PM »
i have the calmini kit and i have brace the sky arm. the Alignment was OK the last time i check.
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #8 on: August 13, 2010, 09:23:15 PM »
i was thing of making  a custom steering links using rod ends
