How the hell do you?
  • 9 Replies
  • 2813 Views
Offline Zuki One
  • 441
    • ZUKI - PICS
« on: June 25, 2004, 10:42:21 AM »
Get the old bushings out of leaf springs? 2hours one and a half hrs 2 drill bits and my girlfriends kid saying POTTY mouth atleast 12 times?they are dry and im putting poly in ;)
« Last Edit: June 25, 2004, 10:42:52 AM by Bug_d »
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: How the hell do you?
« Reply #1 on: June 25, 2004, 10:50:56 AM »
Put a hack saw blade through the hole then attach it to the hack saw. Cut on two sides, beat with BFH and they will come out ;D
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #2 on: June 25, 2004, 10:56:11 AM »
sweet thanx im on my way back out :-/ ;D :-/
Offline Natebert
  • 1098
« Reply #3 on: June 25, 2004, 11:49:18 AM »
blow torch
burn rubber out.
Offline xamtex
  • 72
« Reply #4 on: June 25, 2004, 12:32:51 PM »
yeah the blow torch works every time. ;D
god must love crazy people,he made so many of them!!!
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #5 on: June 25, 2004, 05:16:34 PM »
I tried the blow torch idea on my Bronco2's rear leaf when replacing the shackle mount and all it did was make the rubber hot and smoke... a whole can of propane didn't do it!
Offline jagular7
  • 1026
  • Jagular7
« Reply #6 on: June 25, 2004, 05:50:42 PM »
I've always took a small drill bit to fit between the metal inner sleeve and the leaf spring wrap. This drills into the bushing itself. Drill several hole, all around, then drag the bit from one hole to another. You'll need a small stiff putty knife, a small flat screwdriver, little heat, lots of paper towels. You start to scrape the left over stuff as best as you can. Take some heat to the left over rubber, use the scraper to peel off as much as you can, and use the towels to clear the 'crap' off the scraper. This is a tedious effort.
Lenexa, KS
Offline idaholwb
  • 772
« Reply #7 on: June 25, 2004, 08:17:17 PM »
 A little gasoline, light it and jump back quickly! Let burn in a well ventilated area for a while. When it self extinguishs, try removal. If still not cooperative after 3 burnings, take to a local spring or suspension shop and have them press them out. Problem solved.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline TomKat
  • 211
« Reply #8 on: June 26, 2004, 03:22:30 PM »
   You need oxy-acetylene, burns 'em out in no time. Best way I've found yet.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline suzi_n_sammy
  • 184
  • Rock the Sam
« Reply #9 on: June 27, 2004, 11:56:21 AM »
if you want to burn em out spray some kind of highly flammable spray in there and light it and keep spraying. oxy torch works sweet but not everyone has acess to it.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
