Speedometer cluster
  • 2130 Views
Speedometer cluster
« on: August 15, 2010, 07:34:50 AM »
 My cluster w/tach has bad speedometer, I bought a cluster off e-bay and when I got it ,it was the one without the tach. My question is will it interchange without burning up my wireing and will every thing work?  Thanks  Goldfinder
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: Speedometer cluster
« Reply #1 on: August 15, 2010, 08:25:49 AM »
You should be able to take the speedo abd put it in the cluster with the tach       but yes you can just swap them strait out as long its the same size as the old one        need to say what you are working on samurai   track/kick
« Reply #2 on: August 15, 2010, 05:04:07 PM »
Thank You:  You are right it is a 88 Sammy Thanks Goldfinder
Offline MadMaxZuki
  • 77
« Reply #3 on: August 16, 2010, 07:30:24 PM »
if the speedo is not working its most likely the speedo cable
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline jow003
  • 403
« Reply #4 on: August 17, 2010, 12:23:00 PM »
haha max i was just about to ask a Q about the speedo.  cut my cable when i took out my tcase and hoping it would fix it not working, is there anything els that would make it stop working?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
