Throttle Position Sensor, 98 Sidekick 1600, 16v.
  • 3313 Views
« on: August 20, 2010, 11:38:34 AM »
Anybody have a TPS for a 98 sidekick with a 1600, 16v motor that they would like to sell?
I believe the Standard parts number is TH392.
Thanks,
98redkick
Re: Throttle Position Sensor, 98 Sidekick 1600, 16v.
« Reply #1 on: August 20, 2010, 05:38:17 PM »
I think I have one around here.  Got a pic of it?
« Reply #2 on: August 20, 2010, 08:58:58 PM »
I can't manage to get a picture of it off of the internet.  If you have a 96-98 sidekick or a 96 x-90 with the 16v 1600, it should work.  It has four terminals that you plug into. Most of the other ones have three. It should either be part # th392 or w0133-1816235
« Reply #3 on: August 21, 2010, 06:14:47 AM »
I just have some parts I pulled of some 16V engines...can't remember what years they were.  I will look later tomorrow and see if I can see a part number on it.
« Reply #4 on: August 24, 2010, 06:41:40 PM »
Sorry I haven't gotten back to you sooner.  I haven't had time to look for it.  I will definitely do it tomorrow and let you know.
Thanks for your patience.
« Reply #5 on: August 25, 2010, 09:12:35 AM »
Ok, here is what I found.  The one on the right is from a 96 (which is when they supposedly changed the TPS, but I know that particular one is the same as the pre-96 16V TPS).  The one on the left may be the one you are looking for...I can't remember what it came off of.  Ok, I just remembered I had a 97 16V motor here and I looked at it and the TPS is the same as the one on the left in my pics.  So I am guessing it is the same as your 98.
They both take the same plug.  They both have 4 pins.  All 16V TPS's that I have ever seen have all had 4 pins in them....not sure what TPS you have seen that only has 3...even the 8V TPS's have 4 pins.
Let me know if either of these look like the one you need.
« Last Edit: August 25, 2010, 11:10:03 AM by Skyhiranger »
« Reply #6 on: August 25, 2010, 05:10:54 PM »
Funny, I just finally got time to take a picture of mine (on vehicle). I believe that the 96-98 TPS is the same on the 16v 1600s. The 3 prong one I was speaking of is for the 1800cc motors, from what i have seen on the internet.
« Reply #7 on: August 25, 2010, 05:30:53 PM »
The one on the left, in my pics, is the one that matches yours.
From what I have seen, the 96 1.6s use the older style TPS.  The 97 and 98s use the flatter type.
I'll send you a PM.
