obd2 codes
  • 2334 Views
Offline Bfunk
  • 406
obd2 codes
« on: August 21, 2010, 10:13:44 PM »
I have 2.  The first is easy P0135-O2 sensor.  The next is p0400.  It said egr flow failure on my scanner.  Does this mean I replace the egr or just check all the lines going to it and replace one or more that are leaking???  Just trying to be as lazy as possible so thanks ;)
Brian
Re: obd2 codes
« Reply #1 on: August 21, 2010, 10:18:17 PM »
clean the EGR and the carbon buildup in the crossover passage in the head
Offline Bfunk
  • 406
Re: obd2 codes
« Reply #2 on: August 22, 2010, 07:50:53 AM »
well that's not lazy >:(
Brian
Re: obd2 codes
« Reply #3 on: August 22, 2010, 08:32:52 AM »
Using a can of spray cleaner  ;)
Offline fuzzy1
  • 350
Re: obd2 codes
« Reply #4 on: August 22, 2010, 11:04:18 AM »
You don't say what engine, so I'm guessing '96+1.6 16v... po135 is front o2 sensor heater circuit, can't be repaired, buy a new sensor & replace it. Bosch has a plug & play with the proper 4wire connector. Just be careful removing the old 1 so you don't crack you manifold.
po400 is low EGR flow... most times it can be cured by cleaning the port into the intake plenum & the tube that feeds it from the EGR main. Here's a good pic of the port to clean, looking into the TB from drivers side (1/2 way down page):
http://www.kick-fix.com/EGR-horror2.html
Hth,
Fuzz
Non Illegitimi Conterat
Offline Bfunk
  • 406
Re: obd2 codes
« Reply #5 on: August 23, 2010, 11:43:53 AM »
That's the best answer I have ever seen in my life... wow ;D  Thanks for your time
Brian
ps
Hey Eric, I got a new trackick
