I need help on a transfer case
  • 23 Replies
  • 5924 Views
« on: August 22, 2010, 10:24:58 PM »
The transfer case is grinding in all gears even low. i put it in 1st gear and it just freakin grinds like hell.:( It is a 4.16:1 gearing.
what could be grinding in all gearing, except low range!!!!
Re: I need help on a transfer case
« Reply #1 on: August 23, 2010, 12:53:24 AM »
??? T-case doesn't have a first, but the trans does.
Grinding trying to put it in gear or after it's in gear it
makes grinding noise?
Not grinding in low range ? T-case in low range or trans in
first gear.
Sorry but your post is a little mixed up, I'm trying to 1st figure
out if you know the difference between the t-case and the transmission
and 2nd if the problem is in the trans or the T-case.
« Reply #2 on: August 23, 2010, 07:03:20 PM »
Ok that did sound pretty bad.
So the problem started when i was driving down an old highway doing about 40 mph in 4th gear and the transfer case was in 2wd. It just started grinding terribly out of nowhere.  and i took it out of gear and put the clutch in and i put it back in 4th gear and i t was fine. it also did it in the rest of the gears. it had just gotten worse to where i could not get going in 1st without it grinding. it also grinds in FOUR HIGH but 4 LOW. so hopefully that is a better understood.
« Reply #3 on: August 23, 2010, 07:57:54 PM »
uhhhh.........sure  :-X
« Reply #4 on: August 23, 2010, 08:00:47 PM »
OK lets start with the basics, have you checked the oil in both trans and T-case?
you might want to dump the oil in both and see if there are metal chunks in the
oil or on the magnet in the plug
« Reply #5 on: August 23, 2010, 11:05:48 PM »
yeah i drained the fluid out of the t-case and there was quite a bit of water in it and also some little metel shavings on the magnetic drain plug. so i will tear into it and check everything out. maybe replace the bearings and clean the case out.
« Reply #6 on: August 23, 2010, 11:36:55 PM »
Ya, I bet there are bad bearings in there too and there
might be galling on the gear faces too.
You should drain the trans also, might be water in there too
« Reply #7 on: August 24, 2010, 09:51:44 PM »
ok yeah that is a great idea. i should check that. but the vent hole on the t- case didnt have a hose coming off the top of it.
i am going to buy that kit from trail-gear.com to replace all the bearings. and buy new t-case mounts.
« Reply #8 on: August 25, 2010, 12:07:30 AM »
Ya, you want the t-case and the trans, as well as
both axles to be fitted with tall breather lines to
keep the water a crud from getting in
« Reply #9 on: August 26, 2010, 05:28:58 PM »
i got the transfer case taken all apart and i think the syncros for the input shaft is the part that is grinding. but i didnt get the t-case to grind in 4low so i cant figure which part is grinding. i checked the bearings at they all turn smooth. the only thing i found kind of wrong, was the input shift thing,  shows that it was grinding . what do you think
« Reply #10 on: August 26, 2010, 06:22:03 PM »
The T-case does not have syncros, are you talking about the transmission?
There is a engagement dog in the T-case, I had one wear out, and it would
cause the T-case to pop out of low when I was wheeling, it got so bad I
would put a bungee cord on it to hold it in.
« Reply #11 on: August 27, 2010, 12:31:34 AM »
i am talking about the t case, and yes mine is also popping out of 4 low. which shift fork is used to engage 4low, i see the one at the input shat and the one in the main case. the one for the input shaft i cant get to slide up and down, just wondering if that could be the problem, because i did notice that the teeth on both sides of the shift sleeve were worn down. i didnt see anything else wrong with it. seems like it is in pretty good shape still.
« Reply #12 on: August 27, 2010, 09:50:29 AM »
The one in the front at the input is the high/low shift fork,
the one in the back is 2-4WD and if the front won't move
that is a problem.
« Reply #13 on: August 27, 2010, 08:45:39 PM »
i cant figure out why it wont unless it got jammed in there. there is a small snap ring on the rod of the top shift fork that is not flush with bore, just wondering if it is supposed to shift flush or not.
« Reply #14 on: August 27, 2010, 09:19:04 PM »
Did you remove the detent balls under those screw caps, they are located
in the main body of the t-case housing. If they arent removed, the shafts
are hard to move, and if it's not in 4WD the low shaft is locked into high
by the ball between the 2 shafts
