Specs correct?
  • 1831 Views
Offline BoGiggers
  • 28
Specs correct?
« on: August 24, 2010, 04:22:38 PM »
Here's the link for the 99-05 Tracker specs on ZUKIWORLD Online.
http://www.zukiworld.com/section_technical/technical_spec_vitara.htm
Are these specs right? I thought the 5.12 gears were on the stick version and the 4.88s were on the auto. Also, I have the 2.0 with the auto and it DOES have the lock-up converter. I can see and feel it lock up after it's in overdrive further dropping my rpms. My front diff is aluminum. Doesn't the diff with the 5.12s have a cast iron housing or is that just on pre-98 Trackers?
Thanks!
BoGiggers
Chop what-ch-ya-got!
Offline Frank84
  • 176
Re: Specs correct?
« Reply #1 on: August 24, 2010, 04:47:37 PM »
The spec isn't right for my Tracker.  My '01, 2.0, 5 speed has 4.62 gears not the 4.88's the chart shows.  Maybe Suzuki was different than Chevy, but I'm somewhat doubtful.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Specs correct?
« Reply #2 on: August 24, 2010, 08:18:18 PM »
I'm not aware of ANY Tracker ever built from the factory with a steel diff.  I've had a '95, '96 a '00 and '02 and all had aluminum front diffs and carriers.  The '99 GV with the V6 and manual tranny had the steel housing... not sure of any other Suzuki models with steel diffs unless it was the XL-7s.
I'm going with 5.12 gears on the 1.6 engine manual tranny equipped '96-'98 trucks, 4.62 with the 2 liter manual tranny trucks and 4.88s with the auto tranny trucks 2nd gen trucks.
Offline IanL
  • 466
Re: Specs correct?
« Reply #3 on: August 25, 2010, 12:11:10 AM »
Offline BoGiggers
  • 28
Re: Specs correct?
« Reply #4 on: August 25, 2010, 04:37:14 AM »
Thanks for the replies guys. I swear that somewhere on here I saw something about a cas iron front diff. hmm...maybe I'm just getting old ???
Offline bush buster
  • 263
Re: Specs correct?
« Reply #5 on: August 25, 2010, 07:31:54 AM »
Yep the Zuwharrie site has it right according to the list I got from the Suzuki dealership a while back.
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
