Best Suspension for the Samurai??
  • 9454 Views
Offline BnjmnAlan
  • 10
« on: August 28, 2010, 03:32:33 PM »
I just had to replace the right rear leaf spring pack on the sami this morning.   I have the Calmini 5" reverse shackle kit installed since May 2008 and just noticed yesterday that the second leaf down on that pack was broken.  Anyway,  I've never been overly impressed with this suspension set up.  Really rough ride unless fully loaded, then it is tolerable but it cannot handle any speed on anything but nicely paved roads without kicking your ars.
The samurai has been done a million times a thousand different ways, so someone has got to know by now what the ultimate suspension solution is,  so lets hear it.
It's gotta be a safe and reliable  Daily driver and hang with a built jeep on the rocks and rutts.
Coilover kit? http://www.rocky-road.com/coil.html
Wrangler spring swap? http://www.rocky-road.com/yjkit.html
Plain jane SPOA with stock springs?
What do you think??
Black 1986 Suzuki Samurai 57K original miles.
Calmini 5" RS lift kit.  31" BFG Mud Tires.  GRSII 4.89:1 Low Range transfercase. Lockright locker in rear.  Custom front bumper & Rock sliders.  HD Clutch.  Header w/2" exhaust. Rebuilt front end with cups.  Daily Driver!!
Re: Best Suspension for the Samurai??
« Reply #1 on: September 02, 2010, 09:27:01 PM »
For ease of install and smooth ride you can't really beat the Wrangler spring swap with a traction bar in the back.
I installed a 4 link in the back of my SJ and have been more then happy with it.  It handles much better on the road and soaks up bumps at speed without issues.  If I was going to spend the time to build a suspension I would recommend going straight for coils.
A samurai will never be smooth on rough surfaces though, just not enough wheelbase to soak up the bumps.
Offline BnjmnAlan
  • 10
« Reply #2 on: September 03, 2010, 02:15:41 PM »
Yes, I would love to try a coil suspension, but for the time and money I am really considering the Wrangler spring swap.  It does need a traction bar though?
Did you build the 4 link yourself or use a kit from someone?
« Reply #3 on: September 04, 2010, 01:45:13 AM »
If you only drive it on the road a traction bar is not needed.  But if you do any wheeling and don't have one you will twist your rear springs up.  The very thing that makes it a nice ride, the long soft springs, also means you can get a lot of spring wrap when combined with large tires.
For the 4 link I built my own.  You can read the build thread over at http://zukiworld.com/forum/build-diaries-how-to-diy/sj-410-rear-4-link-build/
With just the stock SPOA on my rig doing a RUF conversion (Rear springs Up Front) made a huge difference in drive-ability.
